rivers24
TLDR; -
Golf 2 door tdi hatchback
1999.5 MK4 in black
Automatic Transmission
207,400 miles
Mechanically Sound
Interior needs some love and attention
$800
The time has come. I've had this baby for over 10 years now, but I've been living in NYC for the last 2 and haven't had a need for a car in a while. It's been sitting in my friends driveway(hasbrouck heights, nj) for a few months. They start it up for me and I drive it around on weekends sometimes, but it's not getting the attention she deserves.
I want to be upfront about this one - while it runs great, it needs some cosmetic attention. It has a few things that you should know about. Here's the list -
1. interior hood latch can be pulled out. It works, but can come disconnected - I never found a fix for this.
2. rear window tinting is bunching up and making it hard to see through. Could be removed or replaced easily
3. Both doors, near the door handle have the cloth coming off. I'll post a picture
4. Windshield has a small crack
5. Interior roof liner is coming off
6. Drivers side speaker sometimes rattles
7. Glove box - lid is gone, wanted to replace but never got around to it.
8. Drivers side door handle got pulled off
9. I painted the front vw logo black, and that finish is coming off
10. Airbag light is coming on, have never investigated
11. Paint on roof is fading
12. Light rust on hood
13. Back right seat belt came unbolted and I haven't re fastened
So this car may make a great parts car, fixer upper or first car.
Here's a list of the most notable work I've had done to it over the years -
Control Arm Bushings, Fuel Temp. Sensor, Injection Pump Seal Kit, Replace fuel temperature sensor
-------Oct 2015 - Left Lane Cars
Suspension upgrade - Blauparts v6 + moog coils
-------Oct 2014 - Cove Auto Repair in nc
Voltage Regulator for alternator replaced, replace climate control switch
-------Nov 2012 - Cove Auto Repair in nc
Kerma mod, AT trans fluid changed
-------December 2009 - Landon Grindstaff in nc
New Injection Pump, Water pump, Timing Belt
-------Nov 2006 - TDI member - pitboy in coral springs, fl
It will need -
Timing Belt in the next 30k miles
EGR Valve and Solenoid should be replaced
Replace Vacuum Pump Gasket/Seal
new brake pads
I've used synthetic 5w40 every 10k since I got it, replaced fuel filter ever 20k and only used tdi club approved mechanics for major work. Tires have about 70% left on them. Battery is brand new VW geniune.
https://drive.google.com/open?id=1Jds-vC1_6t7EwRYxArWhbMfkKEwFEUaX
https://drive.google.com/open?id=1NbICPzgpWZ83T2QIo6yFsHbu-JP0rZmH
https://drive.google.com/open?id=1qX0C3Iww84HX1HwF_uOvA5ttxOksXV9Y
https://drive.google.com/file/d/1T_4sHpYqx2Pc2Kc2GGCBvX2k4bMvjCrd/view?usp=sharing
https://drive.google.com/open?id=1AenJgQhRXeTRXp_OqF9a2ZcJWTOwRhTB
https://drive.google.com/open?id=1yCMvJfTBLEHbdE-uS1asDqm6p1TrsEG5
https://drive.google.com/open?id=1wKaUhDhSfyINcrnK7oiZg_L0l9ykyin-
https://drive.google.com/open?id=1op5V1zHLTGdS4hfu5H3A0wW8OfYDTJEf
https://drive.google.com/open?id=1t8mSN9k3nlHHOz5JIZeRZVBFmn9LFxXp
https://drive.google.com/open?id=1WmRvb-0BOETV7_8MVt5_5BwY0ENyNJFg
1999.5 MK4 in black
207,400 miles
Mechanically Sound
$800
It will need -
new brake pads
