Old October 15th, 2018, 11:30   #1
KarmaKeeper
TDI(s): 2012 Passat
Default Po206 po207
Passat 2012 TDI
Generic MAP installed ran great for 200miles. Then into limp mode throwing codes.
Original sensor only throws intake air temp code without going into limp mode.
Ordered an OEM MAP to install in a few days to see if this trouble stays the same or changes.
Just curious if experience had same results that led to a fix in a different direction.
Thanks for any hints
KarmaKeeper is offline   Reply With Quote
Old October 15th, 2018, 21:53   #2
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Are you sure about those codes?
P0206 and P0207 point to Injector 6 and Injector 7 malfunctions.
PO206 and PO207 aren’t valid codes.
Fixmy59bug is offline   Reply With Quote
Old October 16th, 2018, 07:57   #3
740GLE
Grab ODB Eleven for a cheap VW code reader, otherwise you're reading garbage.
Page generated in 0.13190 seconds with 10 queries
[Output: 53.23 Kb. compressed to 47.96 Kb. by saving 5.26 Kb. (9.89%)]
