Old October 7th, 2018, 18:31   #1
rams2500
TDI(s): 06 Jetta TDI
Default Oil pump "lifetime" belt
I looking to upgrade my 06 Jetta tdi to a Passat. I've been doing some research on the new ea288 engine. 130,000 service interval on the timing belt is a good thing. I'm just concerned about that oil pump drive belt that runs in oil. What happens to people that own these cars up to 200-300,000 miles. Can't believe that belt will run that long. Can't be an easy job servicing that belt. Anyone seen or worked on these engines yet?
06 Jetta TDI Manual Trans, All Stock.
08 Ram 2500 4 door Cummins 4x4 auto. Smarty s67
rams2500 is offline   Reply With Quote
Old October 8th, 2018, 06:46   #2
TheGrove
I have 230,000 miles on mine without any issue with the oil belt.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old October 8th, 2018, 08:55   #3
rams2500
That's on the 2015 model only. New and improved engine over the 2014 and older. Lots of changes.
Old October 8th, 2018, 09:07   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Nobody will have any long term info regarding the oil runner belt on this particular application, however Honda's GX/GC engines have been using them to run the camshaft for a decade or more now, never heard of any problems with those.
oilhammer
www.cardocautomotive.com
Old October 8th, 2018, 09:48   #5
VernK
All just down to material choice. Once you have an oil proof elastomer, the mechanical conditions are very favourable — lots of lubrication fluid, one material much harder than the other and the softer being resilient as well.
Yours
Vern
VernK is offline   Reply With Quote
Old October 10th, 2018, 11:07   #6
740GLE
Change the belt when the TB is done? OH, how hard is it to change the oil pump belt?
Old October 10th, 2018, 11:52   #7
oilhammer
oilhammer's Avatar
Never done one, LOL.
Book time is 3.5hr for both the drive belt OR the pump, but it sure looks like it would take a lot more time than that, due to the dual oil pans both having to come off.
I think 10 years from now we'll laugh about any concern over this oil pump drive belt, since I'd bet 20 other things will be much more common to have to deal with.
oilhammer
Is this tranmission's "lifetime" over? demhaizar VW B5 Passat TDIs 1 July 31st, 2012 00:24
"Lifetime" ATF poll wensteph Fuels & Lubricants 31 January 26th, 2012 18:29
AT "lifetime fluid"? robbyp09 General VW Discussion 2 July 10th, 2006 10:59
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 07:06
Little Brake "Surge" or "Pump" after Braking to Complete Stop Mark Mellblom TDI 101 4 July 10th, 2002 01:55
Page generated in 0.17354 seconds with 11 queries
[Output: 79.74 Kb. compressed to 68.93 Kb. by saving 10.81 Kb. (13.56%)]
