Old September 23rd, 2018, 12:35   #1
oilbrnr
oilbrnr's Avatar
Default DSG to Manual swap
Ive done a couple thousand miles towing a small camper with my 2012 TDI Passat SEL with DSG. In some respects it is working great, in others I'm not so sure. My camper weighs 1k lbs light and tongue weight is around 150#. I have added Sumo Springs to the rear suspension and outfitted the trailer with electric brakes and the car with a controller. Id really like to speak with someone knowledgeable with changging to a manual transmission. Ideally I'm looking for a shop on the east coast with real experience. Any thoughts are welcome....
oilbrnr is offline   Reply With Quote
Old September 24th, 2018, 10:53   #2
jck66
jck66's Avatar
My thought is: it might be cheaper and less painful to buy a manual car than do a conversion. But I am only an "armchair expert".
Can you share your experience with towing - what is it that the DSG is lacking? I'm considering getting a hitch on one of my cars.
TIA
jck66 is offline   Reply With Quote
Old September 24th, 2018, 11:06   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
May not be easy to find one of those with a manual, as most will be crushed.
However, that light of a trailer should give the car, and transmission, no problems at all. While I do agree a manual is better, and gives better control, the Tiptronic function of the DSG like all the other automatics VAG uses since the 01M should allow for all the added control you would need or want.
oilhammer
www.cardocautomotive.com
Old September 25th, 2018, 15:01   #4
oilbrnr
oilbrnr's Avatar
I have towed the trailer a little more than 2500 miles so far. In many respects it is GREAT! I consistently get a little better than 27 MPG towing. The car pulls very well and really doesnt feel too stressed. I added brakes to the trailer (little 7" electric drums) and a controller to the car.......braking performance is stunning. Recently the car is bucking when cold in third gear and possibly in 4th. As soon as the car warms up (3 minutes tops) there is no indication of a problem. The car has 99,000 miles on it and has had all the requisite DSG services done. I plan to service the DSG again at 100,000 miles to have a look at the fluid and to start fresh again. OILHAMMER.....I hesitate to shift the car "manually" but could be talked in to it. I have certainly "intervened" when full auto was not finding the most appropriate gear. That said, I feel that the intended auto function of the transmission is the better choice. What would a "worst case scenario" be of someone using the tiptronic function ALL the time?
Old September 25th, 2018, 22:10   #5
tdiatlast
Armchair enthusiast here, as well. I see nothing in your saga that would indicate there's any need whatsoever with attempting a DSG-manual swap.
Why do you think manually shifting is harmful to the DSG?
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old September 26th, 2018, 04:52   #6
oilhammer
oilhammer's Avatar
The Tip function certainly will not hurt anything... technically it won't let you do something stupid anyway. There is a certain conflict of interest here, as you ask about swapping a manual transmission in... something that MUST be shifted by you ALL the time, yet you are concerned about using the same availability in the transmission that you already have.
I can tell you that I would almost for sure be in Tip mode all the time if I were towing with any automatic transmission so-equipped, unless it specifically had a tow/haul mode available, or there were some really good load sensitive software in the transmission controller. My Sprinter is actually very good at that, but unfortunately while it has a manual mode it does not allow for you to lock it in its highest gear, like your Passat does.
In my opinion, the CR engines work great with the DSG, probably better than any other engine VAG bolted to them, although they still seem a bit upshift happy. I do not like lugging the engine below 2000 RPMs, and would actually rather run it closer to 2500 RPMs when pulling up a hill especially with a trailer. Tip allows you to do that with ease.
oilhammer
Old September 28th, 2018, 07:18   #7
740GLE
1000# is just like loading the car with 4 of your jolly friends and heading off to the Golden Corral for a robust feeding.
If you plan on putting on miles after miles, I'd say shortening up the DSG service interval to say 30K as cheap insurance.
FYI Audi recommends 30K DSG service for some of their A3/S3 lines.
Old October 3rd, 2018, 16:00   #8
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
[QUOTE=740GLE;5444370]1000# is just like loading the car with 4 of your jolly friends and heading off to the Golden Corral for a robust feeding. QUOTE]
Ha,ha,ha, A few years ago I'd swear I saw some people parked at the trough so they wouldn't have to get up to refill their plates.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old October 3rd, 2018, 16:45   #9
PB_NB
PB_NB's Avatar
We have been pulling our trailer for a few years now and often I think a DSG would be nicer a smoother than the clutch especially when starting from a stop one wet roads.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old October 4th, 2018, 05:17   #10
740GLE
I don't want to live in a world where it's not socially acceptable to eat off you're own plate while still in the buffet line!
Old October 6th, 2018, 01:50   #11
Dan C.
Thumbs up
our little 2.0CRDs work well under 2k, I've been 'short shifting' Volkswagens for a long time and haven't had issues from it.
diesels drive much different than gas engines. The torque on a 2.0CRD comes on lower than most people think. No worries good sir!
'97 B4 Passat 397k sold!
'09 Jetta 6M 200k VW bought back Jan '17!
'05 E320 CDI fast fast, wrecked! rebuilding into a project hot rod
'15 Passat SEL Premium DSG
Dan C. is offline   Reply With Quote
Dsg to Manual swap SrtStang Private TDI Items for Sale/Wanted 21 June 25th, 2017 06:28
dsg to manual swap (need help from electrical) emadshaaban VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 7 September 19th, 2015 19:35
DSG to Manual Swap BoostedOne VW MKV-A5 Golf/Jettas 12 January 16th, 2015 16:36
Swap DSG for Manual Transmission Vipervnm VW MKV-A5 Golf/Jettas 2 July 15th, 2011 11:37
dsg to 6sp manual swap, anyone? ObeseFieldMouse TDI Conversions 9 November 19th, 2009 11:00
Page generated in 0.12527 seconds with 11 queries
[Output: 108.08 Kb. compressed to 91.95 Kb. by saving 16.14 Kb. (14.93%)]
