Old September 7th, 2018, 05:25   #31
740GLE
Originally Posted by Jetta_Pilot View Post
I'd turned off all tire sensors, where ever I found them including the one that sets up in the MFD, made no difference at all.
What flipping sensors did you turn off? its a "system" that you turn off via VCDS, can't be done via MFD.
Old September 7th, 2018, 05:27   #32
740GLE
I'll have to compare this to my scan readout and see if they are the same or not.
reading the coding of a module can't be done doing a "general scan" for faults, you keep showing us old codes that were stored, but the meat of the info is in the actual coding of the module. You have to go to the module, ABS module most likely, and read the long coding which is what tadawson provided.
Old September 7th, 2018, 15:19   #33
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
I've been away for a few days.
OK, I've done this as per Ross-Tech some time ago, made no difference.
http://wiki.ross-tech.com/wiki/index...ure_Monitoring
I'll print all of this out and see what develops and get at it this weekend:
http://wiki.ross-tech.com/wiki/index.php/01325
In the meantime since that darn light is on constantly, I took some black electrical tape stuck it to a dime and cut a round circle and taped it so the light cannot be seen for the time being.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old September 9th, 2018, 14:31   #34
Jetta_Pilot
This did/does not help me at all:
tdawson = Was coding on the ABS controller ever verified? And again, did you ever verify coding?
I would if I knew exactly what it is I'm looking for and where.
but my wife's 2015 US SEL has this for the coding in the ABS controller:
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492800FAA30B03EB92210042A1100012
Shop #: WSC 09003 957 00200
VCID: 04296A97875EB761CD-8050
On mine the numbers after Part No HW is 1K0-907-379-60EC1F.clb Sorry I just realized this one is identical 9/10/18
Coding Nr = C54BC0F5492A00FDA30E03E8921F0042A11C0012 This has a number if differences
So there is 1 number different which I did not notice before.
So are you suggesting I should change the numbers to the one from your wife's car?
tdawson = 01325 - but there is no such device by name or the "J502" As per your link to Ross-Tech "Control Module for Tire Pressure Monitoring (J502)"
740GLE = also you can just turn off TPMS all together, nobody needs those nannies anyways
I'm pretty sure I have, but tell me how and I'll re-check it again.
06bluebeetle tdi = When I start the car it flashes and shortly after it stays on solid.
This is the key statement, there is something wrong in the system, whether it is a failed wheel speed sensor or something else,
the light will not clear until you fix it.
If it were just a simple push the button and reset the pressure, it would not flash on initial start, it would come on, go out for a second, then come right back on.
So how do I check these sensors? With a multimeter test for a short?
This is really frustrating !
If someone can tell me exactly what and where and how to do something, would you please simplify it for me and send me a PM. I have to be honest telling me to "check the coding etc" does not mean much to me since I have no idea what it applies to and where and what I'm looking for.
It's much like someone writing a users manual, the author knows exactly what he is trying to say but for the eventual reader it is not the same.
Tnx
Old September 9th, 2018, 22:36   #35
tadawson
Are you using VCDS? If so, open the ABS controller, and go into the long coding helper, and it will tell you what each of the coding digits/bits means (arrow left and right). And also, yet again I find myself needing to remind you that if this is the normal NMS Passat TPMS system *THERE ARE NO SENSORS!* The car uses the abs data to compare wheel speed, and if those had failed, you would have an abs warning as well. If you are using some other tool that does not help you to know what the coding means, that makes things a lot harder . . .
tadawson is offline   Reply With Quote
Old September 10th, 2018, 06:03   #36
740GLE
Having the TPMS light flash on start up and then stay solid is exactly how my 2010 acted when i swapped over to winter tires without sensors. The flashing is the "system" looking for wheel pressure sensors (valve stems).
For the '15 the only sensors you have the system needs to be reading is the ABS wheel speed sensors, if there was an issue with those sensors, you'd have crazy list of ABS related codes stored.
I'd say if you're a betting man, copy tdawson coding and see if it fixes your issue. The worse that can happen is it doesn't work and you can just copy back your original coding.
The other thing is looking at "long coding helper" for specific bits that are different than tdawsons coding.
bits 12, 16, 20, 24, 27, 28, 36.
Old September 10th, 2018, 08:59   #37
Jetta_Pilot
tadawson & 740GLE
We are just getting part of the rotten weather coming up from the south, so I'll check all this tomorrow. I'll copy it to hard copy and take it out to the car.
Thx
Old September 13th, 2018, 09:46   #38
Jetta_Pilot
Originally Posted by tadawson View Post
Not sure how much difference there would be, but my wife's 2015 US SEL has this for the coding in the ABS controller:
Revision: 00H46001
Tried to change the coding to your numbers but when I came to "DO IT"
A message popped up telling me that the code is out of range and was not accepted.
My coding is :C54BC0F5492A00FDA30E03E8921F0042A11C0012
Old September 13th, 2018, 10:32   #39
tadawson
What does the long coding helper tell you the various different bit mean?
Old September 13th, 2018, 11:52   #40
Jetta_Pilot
The Passat is built in Tennessee, you would think the US SEL and Cdn Highline are the same, except speedo and odometer.
Not a heck of a lot to see in Bytes, chose whether car is left hand drive, something like TPMS sensors installed and display added in the MFD.
That's about it 3 items.
Old September 14th, 2018, 05:16   #41
740GLE
Is you're VCDS all the way up todate?
I'm gonna have to dust of VCDS and plug it into our SEL and see what I see in the ABS controller.
Check if anything is checked in bite 14 of the ABS module, if it is, uncheck it and give that a whirl. This is a long shot but it's from the MK5 DIY about converting a direct system to an indirect system.
Old September 14th, 2018, 09:34   #42
Jetta_Pilot
These are the Bits/Bytes I recorded this morning, which seem to be the same as the Long Coding number but broken down in 2's.
My Coding Nr = C54BC0F5492A00FDA30E03E8921F0042A11C0012
C5 11000101
4B 11000101
C0 11000000
F5 11110101
49 01001001
2A 00101010
00 00000000
FD 11111010 May have copied it wrong, but no selection at this Byte.
A3 10100011
0E 00001110
E8 11101000
92 10010010
1F 00011111
00 00000000
42 01000010 select Left Hand Drive
A5 10100001 Select Hill hold and TPMS installed (both checked)
1C 00011100 TPMS via MFD and XDS (Differential lock) (checkmarked)
00 00000000
12 00010010
Also cleared any DTS codes. There are NO fault codes to be found in the ABS controller in today's read. There is one in module 09 Central electronics "status malfunction 0010 and also in 65 Tire pressure malfunction status malfunction 0010
To be honest I'm about to give up on this and will live with a small piece of BLACK electrical tape which is almost invisible hiding the tire sensor icon in the instrument panel.
Old September 16th, 2018, 12:58   #43
TheGrove
Since you cleared all your codes and these came back I don't believe it is a coding issue and more a problem with the tire pressure warning system. I think your only solution will be to take it to the dealer and have them fix the TPS module.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old September 16th, 2018, 15:13   #44
Jetta_Pilot
My vehicle does not have the valve stem sensors:
As posted by 740GLE
I'm just going to leave the black electric tape over the instrument light so it's out of sight. If I feel like it I may take the car to a VW dealer in Manzanillo, Colima this winter to see if they can find anything, I live there for almost 6 months. It will be far less expensive at a Mexican VW dealer.
Old September 17th, 2018, 05:38   #45
740GLE
Sadly still havent broken out the VCDS.
I'd start poking around the 65 tire pressure controller, even though the ABS controler reads the sensor, the tire pressure controller may do the thinking or send the signal for the error light or something.
I don't think Thegrove implied you had well sensor, as there could be something wrong with the "controler" which is part of the "tire pressure system" as a whole.
I'd agree that other then spending more time with VCDS and taking swings at stuff, a trip to a dealer or black electrical tape may be in your best bet.
Low tire pressure warning light skromfols VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 August 31st, 2015 07:23
Finally got the tire pressure warning to go off -- 39 PSI ajm80031 VW MKV-A5 Golf/Jettas 21 June 8th, 2014 06:36
low tire pressure warning light Hayekfan TDI 101 2 December 6th, 2012 20:44
Cool weather -- mileage, and tire pressure warning ajm80031 VW MKV-A5 Golf/Jettas 8 December 1st, 2010 10:10
Disabling Tire Pressure Monitor Warning Light oblo VW MKV-A5 Golf/Jettas 6 November 30th, 2006 20:23
Page generated in 0.15239 seconds with 11 queries
[Output: 141.97 Kb. compressed to 119.22 Kb. by saving 22.75 Kb. (16.03%)]
