Old September 17th, 2018, 14:44   #6826
lb71
Proceedings against Bosch were certified for class action on July 16.
https://kmlaw.ca/wp-content/uploads/...tification.pdf
lb71 is offline   Reply With Quote
Old September 20th, 2018, 13:07   #6827
wolf1389
TDI(s): none
what if we already did the buyback are we eligble for bosch money if there is a settlement?
also is the phase 2 fix mandatory? i would like to buy a used 2015 passat tdi thats already had phase 1 done and do a full tune on it. i would prefer not to have to do phase 2.
wolf1389 is offline   Reply With Quote
Old September 21st, 2018, 16:16   #6828
ecode
TDI(s): Mk6 Wagon
Nobody knows... there isn't a settlement yet. But if its like the USA, Yes.
Why not? The new software was designed to work with the new hardware...
Also, who would sell it now, without getting the second part of the fix and the extra money?
ecode is offline   Reply With Quote
Old September 28th, 2018, 12:23   #6829
wolf1389
TDI(s): none
there are dealers selling off cars that were under the buyback program.. now with drive clean emissions test being removed in ontario i want to buy a 2015 passat or tourag and do a full dpf/def/egr delete and tune
Old October 1st, 2018, 14:17   #6830
ecode
TDI(s): Mk6 Wagon
Those cars would have both parts of the fix done though. If you had a 2015 with only one part done - might as well get the extra part done, and the money, and then tune it.
Assuming the tuning shops can work with a car with the fix. I would imagine that's not a huge problem though.
Old October 5th, 2018, 05:02   #6831
xpert
Hello,
I called to schedule my Phase 2 appointment and the dealer said there is a hold on the phase 2 from VW and they will get back to me once the hold is removed. I spoke with several people. Eventually someone said that there could be something not going well with the fix and VW is looking into it. Anybody knows anything about this?
xpert is offline   Reply With Quote
Old October 5th, 2018, 13:45   #6832
Nuje
Fuel Economy: 1200km/tank (Mk4); 750km/tank (Mk7)
When the dealer here did my phase 2 fix, they boofed (Kavanaugh would suggest I'm using the term correctly, I think) the installation or connection of something and I ended up with a leak at the DEF injector. Had to bring it back in a couple thousand km later with the crystallization around the injector for them to remove and replace.
Whether that's bad work on their part, or bad part(s) from VW's...???
Nuje is offline   Reply With Quote
Old October 5th, 2018, 13:55   #6833
The Tortoise
Originally Posted by xpert View Post
Hello,
I booked my Phase 2 appointment yesterday (in two weeks) and nothing was mentioned. '15 GSW.
It could be they don't have the necessary parts in stock.
The Tortoise is offline   Reply With Quote
Old October 9th, 2018, 09:40   #6834
Loafing
Fuel Economy: 5.2l/100km (54.3mpgImp/45.2mpgUS) avg on 233,000km as of Nov 2018 (light footed)
Default Leaking DEF injector
[QUOTE=Nuje;5446448]When the dealer here did my phase 2 fix, they boofed (Kavanaugh would suggest I'm using the term correctly, I think) the installation or connection of something and I ended up with a leak at the DEF injector. Had to bring it back in a couple thousand km later with the crystallization around the injector for them to remove and replace.
Thanks for posting, prompted me to lift the hood after repeated "Error: AdBlue........" warning. Have exactly the same problem. My pic was taken about 1000 km after first warning "Error: AdBlue......" ps Nuje, thanks for the help in getting this on the forum!!!
Loafing is offline   Reply With Quote
Old October 18th, 2018, 12:04   #6835
xpert
I just got a call from the dealer to say that one of the parts for the Kit A is back ordered and not available momentarily throughout Canada. I am curious if your appointment is still on. Anybody has had Phase 2 performed on their 2015 TDI performed recently?
Old October 18th, 2018, 12:25   #6836
The Tortoise
Mine is going under the knife next Tuesday and I haven't heard anything. When I booked the appointment he did comment that I was lucky it was a Golf because parts for other models are back-ordered.
Old October 18th, 2018, 12:31   #6837
xpert
Thanks for the reply. I hope it will go well. Please do keep us posted.
Old October 23rd, 2018, 18:29   #6838
onslaught192
Default wheels/tires
Booked my turn in appointment and the rep from the settlement phone line mentioned all the items to bring with me and she specifically mentioned original MAG rims
What if i don't have them? She said it's in the settlement agreement but i can't find it anywhere.....are they really being this stingy?
mine were damaged over the years from potholes during the winter thaws and i have used steel rims ever since.
What should i do? go to a scrap yard and buy used ones? do i explain this to them when i get my 20 day call back?
onslaught192 is offline   Reply With Quote
Old October 23rd, 2018, 19:58   #6839
GD
GD's Avatar
I would turn it back with the rims and see if it flies. If not go back with some MAG's or try another stealer,
TDI'ers Do it Better!
2007 Benz ML320 CDI too many toys to list
2011 Jetta TDI (CJAA) Highline DSG Reflex Silver 165,000 kms
2004 Jetta TDI PD (BEW) Platinum Metallic Grey 340,000 kms SOLD
2000 Jetta TDI ALH Black 398,000 kms, TT LCA Bushings, TB changed at Windex GTG SOLD
GD is offline   Reply With Quote
Old October 24th, 2018, 12:06   #6840
zaphod99
As others have said in this thread, the settlement agreement makes no mention of the original wheels, so VW/Ricepoint don't have a leg to stand on.
I returned mine on steelies about 6 weeks ago. This triggered an additional 10-15 minute call from the RP agent to the "mother-ship", but after that they took the car as is. I overheard the agent answering a question with "yes that all that's missing". So I guess once they realized that I wasn't a "stripper" they backed off.
zaphod99 is offline   Reply With Quote
Dieselgate fix spicy_red General VW Discussion 2 April 2nd, 2016 04:33
FREE: 1988 Jetta owner's manual (Canadian English edition) weebl Private TDI Items for Sale/Wanted 1 January 12th, 2015 21:20
2013 Golf Canadian Wolfsburg edition ggriffis420 Golf TDI Picture Gallery 4 September 12th, 2013 17:23
2004 TDI Sport Edition (Canadian Car, here in Michigan) smelthead TDI Cars for Sale/Wanted 2 November 25th, 2008 07:00
VDO group buy feeler (Canadian edition) flair.14 Private TDI Items for Sale/Wanted 13 March 24th, 2003 07:24
Page generated in 0.25082 seconds with 11 queries
[Output: 130.39 Kb. compressed to 109.92 Kb. by saving 20.47 Kb. (15.70%)]
