Old November 5th, 2013, 13:37   #1
DieselBrownie
TDI(s): '13 Passat
Default Lifter noise on cold startup.
Hey folks, I Just thought I'd pass along some info about an ongoing situation with my car, in case you're having the same symptoms.
My '13 passat TDI has been exhibiting a noise on cold start-up that sounds a lot like a collapsed lifter. This began right around my 10k service and I'm currently just over 20k miles. Upon a few visits to VW, (and them "not finding the problem,") I decided to make a youtube video of the elusive sound.
http://www.youtube.com/watch?v=unDplH7Ago4
In the dealer's defense, the sound didn't present itself every morning as loud as you hear in the video, but it was there none the less. I was a mechanic for about 10 years, and recognized the sound right off, but I'm sure the service department talks to lots of "mechanics" who bring their car in for service.
Upon showing the service department my video, I was given a loan car, and have been in said loan car for about two weeks now. I was called last Friday by the service manager and told that VWOA's area technical representative had authorized a set of tappets to ordered and subsequently installed in my car, which should be completed sometime this week.
When I first came across this problem, I searched this forum for similar occurrences, but only found instances of the AdBlue solenoid doing its purge at start up. As you'll see in the video, this noise is quite different, and occurs concurrently with the solenoid's noise. I'm hoping that this is a rare and limited occurrence, but in the case that it is not, I'd like it documented here for others to search and see.
I'll likely have my car back soon, and I'll give an update on whether or not this fixes the problem.
-Matt
'13 Passat
'05.5 Jetta-Sold
DieselBrownie is offline   Reply With Quote
Old November 5th, 2013, 13:58   #2
unixb0y
-Matt
People have mentioned in the past the the DEF pump makes a clicking sound when purging the air from the def lines.
Does your ticking sound go away?
unixb0y is offline   Reply With Quote
Old November 5th, 2013, 14:34   #3
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
If that were an ALH TDI, I'd say it was compression blowing past an injector seal. Did you pull the top cover off to see where the noise was coming from (a piece of hose works great)?
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old November 5th, 2013, 15:07   #4
ChadS99SVT
what are these tappets?
ChadS99SVT is offline   Reply With Quote
Old November 5th, 2013, 15:23   #5
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Something that the CKRA engine doesn't technically have. But the idea is the same, it has HLAs (Hydraulic Lash Adjusters) under the end of the roller rockers.
My ETKA is down right now, so I can't tell you exactly what VAG calls them.
Of course, right from the book in the lash adjuster section it states "irregular valve noises are normal when starting the engine" and then they give a simple procedure for checking them. But this involves running the engine for 2 minutes at 2500 RPMs.
oilhammer
www.cardocautomotive.com
Old November 5th, 2013, 15:47   #6
ChadS99SVT
so is what he is experiencing an actual problem? (may be hard to say).
for some reason I think my car might make this noise but not really sure. I will be listening for it now.
Old November 5th, 2013, 15:50   #7
Good Ol' Boy
VeeDubTDI's Avatar
Ours has occasional lifter tick on startup. It doesn't seem to have any rhyme or reason and it's been doing it for quite a while... fortunately it goes away quickly so I'm not too worried about it.
I also noticed this on GeekDrew's car.
Old November 5th, 2013, 16:20   #8
DieselBrownie
TDI(s): '13 Passat
It does. This sound lasts anywhere from 1-3 minutes, depending on how fast the car warms up.
*Edit: The lash adjuster sound goes away. I'm familiar with the sounds the after treatment systems make, and I indeed have those sounds as well. This particular sound is RPM dependent, at 1/2 crankshaft speed.
'13 Passat
'05.5 Jetta-Sold
Old November 5th, 2013, 16:23   #9
DieselBrownie
TDI(s): '13 Passat
I pulled the cover off to put a stethoscope to it, just to try and get an idea of where it was coming from. There was no change in driveability whatsoever, and it just had that loose valve sound!
Besides, at 20k, this baby is VW's to fix.
'13 Passat
'05.5 Jetta-Sold
Old November 5th, 2013, 16:25   #10
superchud
I experience a similar sound when starting mine up in the morning. Goes away after a few min. I just chalk it up to cold engine as my previous gasser did the same thing.
superchud is offline   Reply With Quote
Old November 5th, 2013, 16:27   #11
Good Ol' Boy
VeeDubTDI's Avatar
It's important to distinguish between the AdBlue injector's normal clicking and actual valvetrain noise. Make sure you know which one you're talking about. AdBlue injector is perfectly normal, while valvetrain noise is questionable, although it has been reported by several people so far.
Old November 5th, 2013, 16:36   #12
DieselBrownie
TDI(s): '13 Passat
Thanks for the reply! I thought you might have a better idea how this system worked... Having never pulled the valve cover on one of these newer engines, I was curious as to how this was all set up. The service manager called it a tappet, and being overhead cam I figured it had some sort of hydraulic follower (like what you used to see on Chrysler products.) Is it more similar to a shim bucket (like what you commonly see on Asian cylinder heads?)
I don't doubt VW would write this as normal in the manual (typical car manufacturer behavior,) as there's no telling what sort of warranty claim this is generating. It'd be one thing if the noise went away as soon as oil pressure developed, and if all 16 lash adjusters did it, but it's only one, it's super loud, and it takes several minutes to pump it up.
It kind of reminds me of when Toyota was blaming the customers for their v-6's sludging up, saying it was a lack of maintenance (despite perfect records from customers.) It took many a lawsuit to turn all that around, to what became the great technician money-maker of the early 2000's.
'13 Passat
'05.5 Jetta-Sold
Old November 5th, 2013, 16:49   #13
DieselBrownie
TDI(s): '13 Passat
It's pretty easy to distinguish, as the sound I'm complaining about is RPM dependent, at 1/2 speed of the engine. It really stuck out to me, because I worked for a GM shop back when they were in the habit of putting ****ty roller lifters in their v-8's. Symptoms were nearly identical, and I couldn't tell you how many sets I put in! Needless to say, I was disappointed when I heard this sound coming out of my new car. Then again, any car can be built on a Monday...
'13 Passat
'05.5 Jetta-Sold
Old November 5th, 2013, 19:04   #14
ChadS99SVT
Yeah I'm thinking I've heard something similar but just started mine after sitting for close to 24 hrs and it sounded solid.
I will keep an ear out.
Old November 5th, 2013, 23:51   #15
jrm
Fuel Economy: 42/52
Wife leaves 30 minutes before I do and every morning I watch her and my 3yr old back out of the garage- the ad blue pump sounds more like a bad belt than a lifter. No lifter sounds on mine yet.
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
2009 CBEA lifter noise at startup Rod Bearing VW MKV-A5 Golf/Jettas 51 December 12th, 2009 21:00
lifter noise when cold start?? forrest resto`s TDI 101 8 September 26th, 2007 19:31
lifter clatter on startup bluecollarpilot Fuels & Lubricants 23 July 21st, 2006 08:43
new noise upon startup in cold weather oldpoopie VW MKIV-A4 TDIs (VE and PD) 4 January 11th, 2004 20:56
Whirring noise after cold startup? Fabia TDi VW MKIV-A4 TDIs (VE and PD) 17 January 15th, 2003 09:42
Page generated in 0.18993 seconds with 11 queries
[Output: 136.17 Kb. compressed to 114.08 Kb. by saving 22.09 Kb. (16.22%)]
