Oil Change interval
50 MPG
Durham, NC, USA
2003 Golf
My mechanic recommends changing oil every 5K miles in my 03 Golf. We are using Motul 5w40 x-cess synthetic. The owners manual specifies 10K miles. I hope to run the Golf to 300K miles. I'm at 105K miles and she runs great. Which one should I listen to?
50 MPG
Durham, NC, USA
2003 Golf
Sorry guys. As you can see, I'm a brand new newbie. This has been done to death, and the answer for VW specified oils is 10K. I'm pretty sure the Motul we use is at least as good. Let me know only if you disagree about the quality of the oil.
SyNtAxx
Philadelphia Suburbs.....
2001 Tornado Red GLS TDI
I change mine at 10k mile intervals. Sometimes 12k miles. Ther is no need to change sooner then 10k. Unless you like spending 2x as much money then needed.
I am sure most here will say the same. Some may even advocate for longer intervals. If the manual says 10k then you cant go wrong at 10k, provided you use the proper oil, etc.
I cant speak for your choice in oil. I have only ever used Mobil 1 Turbo Diesel Truck or Rotella T6, both 5w40.
Nick
yatzee
Montreal, Qc
see sig
Nick
x 2. no reason to do 5k intervals. I would question whether your mechanic knows anything about tdi's
dieseldorf
MA
ex- 1996 wagon, ex-2000 Jetta
50, welcome aboard! You're throwing away perfectly good oil every 5,000 miles.
ruking
San Jose area, CA
2003 VW Jetta, 5 M, Reflex Silver: 09 Jetta, 6 Sp DSG, Candy White: 12 VW Touareg, 8 Sp A/T, Flint Gray
Actually, you can use a wide and ever expanding choice of oils. (5w40's:) Castrol, Motul, Total, Mobil One @ least 4 products, Fuchs, Amsoil, Redline, Rotella, etc,. I am sure I have left out some favs.:eek: I have and continue to use Delvac One 5w40 (aka Mobil One 5w40 TDT). The oem filters and the vendors that do the oem filters; like Mann, Bosch, Hengst, etc., are all specified (made to go) to 50,000 kms (converts to 31,069 miles).
Since the conversion from LSD to ULSD (Oct 2006), I have been running 25,000 miles OCI's. My last one was 30,700 miles. @ 154,000 miles this thing runs like the proverbial top.
ymz
Between Toronto & Montreal
2003 Jetta TDI Wagon, 2003 Jetta TDI Wagon
Most any diesel-rated 5W-40 oil you'll find around here is good for at least 10,000 miles oil change intervals... many of us run 15,000 miles or more routinely... (my 2003 has over 400,000 miles now...) However, if you don't drive enough, I'd change it once a year, at least...
Personal favorites:
Mobil-1 Turbo-Diesel Truck 5W-40 (new version of Delvac-1) - found affordably at most WalMarts in the U.S.
Shell T6 5W-40 - again, at most WalMarts in the U.S.
Petro-Canada "Duron" 5W-40 - hard to find in many areas...
Castrol "Syntec" 5W-40 - European Formula (used to be the house oil at most VW dealers once upon a time... now they need to stock newer oils, some of which may not be ideal for your car... most here prefer 5W-40...)
Although I've never used it, many just love the Amsoil "European Formula" 5W-40...
Your Motul should be fine for more than 10,000 miles as well...
Welcome to the TDI-Club !!!
Yuri
richmondvatdi
Chesterfield, Virginia
2005 Passat Wagon 5-speed,2003 Jetta GL Wagon, 2003 Jetta GLS Wagon, 2013 CC 2.0T
Since the conversion from LSD to ULSD (Oct 2006) I have been running 25,000 miles OCI's. My last one was 30,700 miles. @ 154,000 miles this thing runs like the proverbial top.
Wow! I'd love to be able to stretch it out a bit. Seems like that 10,000 mile interval comes back around in a hurry.
Ski in NC
Wilmington, NC USA
2001 Jetta ALH 5sp stock
On my '01, which has the same engine as your '03, I took two oil samples at around 10k miles of oil use. Lab analyses indicated oil was less than half way through it's useful life. So yes, 10k changes are fine and even conservative.
Enjoy the car!!
85_305
Banned
Buffalo NY/FT Bragg, NC
1999.5 Jetta 5spd
Enjoy the car!!
Are you serious??? Thats awesome. Thats some excellent proof to OCI's as well.
MonsterTDI09
NoVa/NJ
2010 Jetta DSG/ up keep on 2009 Jetta DSG 2006 Jetta Pag 2 in North SEA Green
Welcome to the club. Every 10K for O/C and do a UOA and go from there.I use Blackstone there are others.Good luck
procupine14
Kansas City, MO
2003 Beetle 5sp
Well, I know in europe they have the same engines that we have and their OCIs are variable, usually carrying them all the way to 30,000 miles in some cases.
I'm pretty sure 10,000 miles is just fine if not conservative. 5k is just way too soon and synth diesel oil is expensive so why throw it away early ;)
jnelly
Minneapolis, MN
'05 Golf GLS 4D 5spd
Let's see if I can revive an old discussion. I've read through a lot of threads about OCI and still have one thing to clear up.
My mechanic (actually the guy at the front desk) told me to stick to a 5k mile OCI because the filter only lasts that long, and I could damage the turbo if I try to push beyond that. I'm not sure which filter they're using (i assume MANN), but he claimed the stock filter that comes with the car is the only one that can do 10k miles, and, unless you're getting your filters straight from VW, anything else is only going to last 5k miles.
Thoughts?
(BTW I often change at 10k still, but in my head I have to add 5k to the sticker they put on my windshield)
tdiman
bridgeport wv
jetta 2015 sel grey / black interior
oil changes
Iif you do a oil analysis u can do 15,000 miles on oil changes with no problem .
coalminer16
Central Wisconsin
Golf 2004
And what part of the filter is he saying fails? Does it just dump the load of filtered crap back into the system. Does it over pressure the system before the filter? Does it get them twice the business for oil changes? I go with the last one.
The US is so into the 3-5k oil changes it makes me laugh. Better engine designs, materials, oils and filters have come a long way from the open crank shaft engines of the 1920's that had grease cups rather then oil. I have heard from a lot if sources on here Europe does a 20k oil change but they dumbed it down to 10k for us since they knew we wouldn't go that far.
Only stuff I find in the filter rarely is a flake of shinny metal which i then start to look at the cam. Cut a section out and press between a rag in a vice. Then you can inspect.
Sent from my SM-G950U using Tapatalk
tdiman
bridgeport wv
oil changes
I plan on doing 20,000 miles this time on my oil change . Did a oil analysis at 10,000 miles and there where no sign of ware . All oil specification where good . Also did a oil analysis on dsg at 40,000 and oil was in specification. Will also double that service interval . This is how the dealers make money getting u to come back sooner. just check and top off oil as needed
turbobrick240
maine
That guy at the desk doesn't know what he's talking about. Go with the 10k mile interval. The filter will be just fine. Lots of brands of filter that work great for 10k+ miles.
TDI smile
Edmonton, Alberta (b4 BC - LOWER MAINLAND = Chilli
2002 TDI (ALH) with 513,000 km. First Owner and very happy... No Problems, never left us stranded on the Highway. Average useage is about between under 4 ltr. and 5 ltr. Normal longdistance travel: 4.1/100
I go with the MANUFACTURERS recommendation = 10,000 miles or in my case 16,000 km. I'm still on my original Turbo at 479,xxx km.
jokila
Houston, Texas
2003 Jetta GLS, Manual
Thoughts?
On your next change, get it to the even 10K mileage and you will never have to remember. It's easy to recall mileage like that.
And... stop reviving threads. Just make a new one and reference the thread with a link.
oilhammer
outside St Louis, MO
I do 20k miles on my ALH.... 542k miles and climbing. 505.00 spec 5w40 and Mann filter, maybe ~2L total top up between services (added maybe .5L at a time throughout the run). I do almost all highway, and have a MAF delete mild tune. 10k is easily safe. 5k is just stupid. And wasteful.
KLXD
Lompoc, CA
'98, '2 Jettas
Yeah, don't revive threads. It's so much easier for people searching when there are multiple threads on the same subject. :rolleyes:
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
I've found the opposite to be true, less threads with more info.
But you know, folks seeing things in different light is actually a good thing!
Some forums will address this in Rules, but here at Fred's, they're more laid back, and some see that as a positive, some negative.
We sure don't need more discussion of tires, air filters, oil.........
Rodmiser
N/A
Jetta s\DSG 2015 & 1&2 FIX
VW Service light
My Light is set at 8000 miles or 12874 km.
507.00
bizzle
Southern California
2015 GSW SEL (totaled), 2013 Touareg Executive
507.00
Mine has always been 10K, but the last time my oil was changed it was done at the dealership and now coming up on 8K saying it's due.
Did the dealership reset my interval incorrectly? Now I'm not even sure that they put the right oil in it if they were re-setting it to some other make/model interval. :eek:
Would I have even known if the oil was wrong within 8K miles?
Mongler98
COLORADO (SE of Denver)
im sure that the oil can handle that but not the filter.
20K is a lot for a filter to take, do you send out oil samples for testing to blackstone labs?
oilhammer
The filter is fine. And yes, UOA were great at 10k and only marginally worse at 20k. I only needed to test it once, to set the trend, that was 100k miles ago... enough for me.
