Old June 28th, 2014, 22:59   #106
jrm
Fuel Economy: 42/52
that's my video, what's odd is it has never done it since- All I can think is that on the last shutdown whatever lifter was compressed leaked down more than the normal amount and took higher oil pressure to pump back up.
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
Old October 4th, 2018, 10:29   #107
rabbit85
rabbit85's Avatar
Fuel Economy: 8.5 liters - city, 4.5 liters out
Originally Posted by Driver_found View Post
Update for those following this. Lots of parts thrown at this, including new lifters, new ECM, new injectors, new fuel, and @ a month in the shop. VW is deeply involved now, but still not fixed. Loud lifter(s) noise, and dramatic drivability issue when cold started is still present. Dealer has been nice, but this process has taken way longer than I expected.
Especially with VW calling the shots on what to fix.
Observation. If VW doesn't know how to fix it the first time, then who you gonna call?
I don't think is the best way to solve that ticking noise. Only God know if the noise were from the lifters... In real the noise come from the right back of the engine and it has nothing to do with the engine body.
rabbit85 is offline   Reply With Quote
Old October 5th, 2018, 20:26   #108
jrm
Fuel Economy: 42/52
yup, my car has never made that noise since.... but I have also moved away from that crap 5w30 and went to T-6 5w40
2015 Passat TDI SEL
Old October 17th, 2018, 13:25   #109
rabbit85
rabbit85's Avatar
Damn it.... I believed in myself that 5w-30 is a crap, but unfortunately is imposed for DPF. Still when it's cold the oil it's like water. It means your DPF is off, which is very good. The engine should sound like a petrol now
2009 CBEA lifter noise at startup Rod Bearing VW MKV-A5 Golf/Jettas 51 December 12th, 2009 21:00
lifter noise when cold start?? forrest resto`s TDI 101 8 September 26th, 2007 19:31
lifter clatter on startup bluecollarpilot Fuels & Lubricants 23 July 21st, 2006 08:43
new noise upon startup in cold weather oldpoopie VW MKIV-A4 TDIs (VE and PD) 4 January 11th, 2004 20:56
Whirring noise after cold startup? Fabia TDi VW MKIV-A4 TDIs (VE and PD) 17 January 15th, 2003 09:42
Page generated in 0.13964 seconds with 13 queries
[Output: 66.85 Kb. compressed to 59.96 Kb. by saving 6.89 Kb. (10.30%)]
