DocMaddie
Had a shop install the Dieselgeek full metal jacket. About 5 miles after picking it up, developed a loud turbo leak/hiss, from the passenger side wheel well. I have already done the dog collar upgrade for the upper hose. Called the shop and confirmed that they had removed the lower hose when installing the skidplate.
Got under the car tonight and surprise surprise, the lower intercooler hose was loose at the fitting to the intercooler. That stupid clip that is similar to the one I fixed with the dog collar on the upper hose. I can not for the life of me get this thing to lock back into place, probably worn out. What an awful design.
I would like to avoid having to deal with taking this back to the shop, and also even though they are a VW shop, they kind of screwed this up once so I am worried they might do so again. What is the best fix for this mess? I have seen discussions of this problem but no-one having a good solution. Tried a wire-tie temporary fix which was a fail. Don't want to screw it in out of concern for messing with the airflow dynamics.
