It is sort of like the dictum check your tire pressure when cold. Well, what happens when you have to check it when it is hot?
ruking, you're generally correct but it leads to further interpretation by the operator of defining what's "hot" and what's "cold". Is the car being run in Alaska or Miami? When you can't trust the general public to tie their own shoes, adding this temperature "attribute" to checking engine oil could become a disaster. This also can be witnessed by the fact that you can no longer check the auto trans fluid level 'cause the operator can't determine the temperature of the fluid in the transmission....same dilemma. So, to simplify, mfrs tell people to check the engine oil level when the engine is up to temp so there is a uniform basis of comparison. VWoA has had huge issues with this and issued the TSB covering it.
How many car companies need to issue a 5 page technical bulletin explaining how to check the oil level
Crazy stuff but it's reality.
If your dipstick reading is in the upper portion of the cross-hatched area, regardless of engine oil temp, you should be “safe”. The VW’s cross-hatched area is very short compared to other cars meaning they consider that level critical, IMO. On my GM car, that cross-hatched zone is two or three times longer than the VW but the cars both have the same sump capacity.
I am most comfortable keeping the hot oil level close to the top of the cross-hatched area and never have any worries with this strategy...on any vehicle
