danski0224
It seems that the glow plug harness is the root of many TDI evils, and it could be a cause of some of my problems.
It seems that the glow plug harness connectors can't be cleaned, and the only option is replacement.
Has anyone attempted to coat the glow plugs/fill the connectors with dielectric silicone grease (or just plain old grease) to ward off harness terminal corrosion?
When I inspected my electrical contacts, I noted that there wasn't any grease in there.
When I replaced the alternator harness on my 87 Ford F250, the replacement came with a generous amount of silicone grease, and I have also always greased my battery terminals and taillight sockets to ward off corrosion. Spark plug boots, too.
The only reason why I haven't greased those glow plugs is because of the engine computer, and I do not know what (if any) the effects may be.
