gottdi
I hooked up my vag-com yesterday and found these:
4 faults found:
19561- valve for intake manifold flap (n239): open or short to ground
p3105 - 35-10 - - - intermittent
17664 - engine coolant temp sensor (g62) open or short to plus
p1256 - 35-10 - - - intermittent
19586 - egr system regulation range exceeded
p3130 - 35-10 - - - intermittent
16764 - glow plug/heater (q6) circuit: malfunction
p0380 - 35-00 - -
I have cleaned the intake without busting anything and all vaccum holds and electrical connections are tight. Runs good. What valve? How to check it? I don't have my book yet but soon. Need images to find it.
Same for the coolant temp sensor.
Egr regulation range exceeded? Why would this happen? What causes it?
All glow plugs check good and have been replaced two weeks ago with new glow plugs. What is the heater portion of this code about? I have been looking around my vag-com stuff I have printed from the forum but found nothing yet.
By the way, the first two would not clear and the bottom two did but came back when I started the car.
Please help. The car is a 2001 Beetle TDI
Thanks a bunch
gottdi
4 faults found:
p0380 - 35-00 - -
Thanks a bunch
gottdi
