'97 AHU into ’81 Rabbit LX
ToddA1
NJ 08002
It's been over a month since I've worked on the car. Sunday, I cut off the clamping tabs in the engine bay, shot some self etching primer, and airbrushed some single stage.
Last 2 nights were spent prepping the wiring. Working on one connector at a time, cutting all the tape off, cleaning off the tape slime and depinning any wiring that won't be needed. Haven't pulled as much as I expected so far... ABS, fog lights, corner markers, etc.
Cleaned harness gets bundled and tossed to the back once completed. Pulled wire goes to the right and is neatly bundled in case it needs to be put back in or used as a repair wire.
Found plenty of burned areas in the ignition switch harness... need to be revisit this harness.
Printed and laminated a copy of the A2 Resource. Some of the wire colors aren't accurate, but it's still very helpful.
Verifying everything against the Bentley. Wished the diagrams were as easy to read as the old Rabbit's Bentley.
My trusty VAG terminal puller has served me well for the past 5 years.
Tonight, I finally found a need for the smaller tool. Need to make one....
-Todd
ToddA1
NJ 08002
I didn't do anything yesterday other than make a "micro" terminal puller. Used a handle from a Harbor Freight pick. Turned out so well, I decided to make another "junior". Not going to retire the OG tool... it still works fine.
It was a little cooler in the garage (only 88°), so I set up shop and kept cleaning out harnesses.
Everything hanging from the bungee has been gone through.
Any reason why the seatbelt buzzer goes through the radio harness?
-Todd
ToddA1
NJ 08002
I started thinking how I'm going to run the engine harness. Because I plan on running AC, the plenum box in the raintray needs to stay. The wiper motor and linkage consumes a decent amount of space too.
Mounting the ECU in the raintray and keeping it safe from the weather will be very difficult. I decided to mount the ECU in the car. It would be mounted at the right kick panel, where the Jetronic box would be mounted if the car were CIS.
To do this, I needed to de-pin each wire from the ECU plug, pull it through the rubber boot and thread it the opposite way through the firewall grommet. Then reconnect at the ECU.
I didn't want to cut anything, so some of the wires needed to be pulled from the fuse panel connectors, because if the factory splices. I ended up having only one connection (at the N75) fight me and it needed to be spliced.
Where the harness would normally go into the bay and branch to 2 harnesses, it now only has one branch.
Because the ECU was normally in the raintray, some of the wires for the N75, coolant glow plugs, etc are too short. They'll need to be lengthened. I haven't decided how I'm going to run these.
I also started sorting out the rear harness. My original plan was to use as much of the CE2 harness as possible and recreate the Rabbit harness. I'd only splice in the taillight and plate light connections.
Rethinking it, since I'm already splicing, it may be easiest to splice about 3' into the harness where it lays along the rocker. As long as all of the wires/sockets tone out, I should be good. Haven't made up my mind....
-Todd
ToddA1
NJ 08002
Finished the rear harness. I decided to use more of the CE2 harness, than the the Rabbit harness. All solder joints were staggered and covered with adhesive lined shrink tube. Not sure if I want to stuff the harness into loom.
Ordered some dry vinyl tape to wrap the harness. To prevent unraveling at the ends, I used silicone self fusing tape. If I was able to pull the pins from the plug, shrink tube was used.
I decided on running the rear harness inside of the quarter, rather than in the hatch, and needed to drill an access hole. I wasn't thinking and didn't protect the outer skin... the hole saw's pilot bit poked the outer skin. Not happy....
Barely noticeable, but I made it worse with the hammer and dolly. Hopefully the PDR guy can get it out.
Decided to try and hide the lighting and engine harnesses... I'll be running them in the fender well. The fender was seam sealed where it meets the apron, so I had to work from inside.
Left fuse panel bracket was cut off (again) and I needed an angle drill for one hole. My old DeWalt batteries won't take a charge and didn't want to buy another angle drill or more batteries.
Used a 1.625" hole saw and opened it up to 45mm with a die grinder and double cut carbide burr. Harness grommets fit perfectly.
Scrap metal was welded to the cut off bracket and a bolt was welded to it. The bolt goes through an existing hole in the body bracket. The bracket is now removable, if I need to mess with the wiring.
I stopped using the retractable drop light years ago, so it became a 3 way outlet. Drop light shield was recycled into a shrink tube attachment for the heat gun.
Seems I did more planning and staring... doesn't seem like a lot of progress....
-Todd
ToddA1
NJ 08002
Minor progress.
A while back, I decided to run the A2 CE2 stalks. It seems the stalks with hazard are a bit harder to find since they were only out for 2(?) years.
Took a while to find one with the integral hazard switch and when I did, it was faulty. Second one I found seems decent.
Took it apart, cleaned out the old grease and corrosion and reassembled. I doubt the cruise function would have worked.
FWIW, I found an aftermarket turn stalk with hazard button on Ebay for about $25 shipped. If you have a cruise stalk, simply swap it. I could have gone this route.
I also bought a CE2 A2 headlight switch plug. Less splicing, the better....
I'm going to need to figure out the AC harness and what fans I need to run. Not sure if I want to go fixed displacement on the AC compressor.
-Todd
ToddA1
NJ 08002
I spent the day staring and planning... I roughly hung the ECU harness in the car.
The loose wires turned to a tangled mess, when pushed through the new kick panel hole. Spent a decent while, trying to straighten them out.
I needed to get an idea how I was going to run the short wires for the coolant glow plugs, N75, etc.
I decided to place the coolant glow plug controller, N18, N75 and the in the rain tray. The wiring will enter through the existing hole for the speedometer cable.
I used scrap wire pulled from deleted harnesses and lengthened what I needed. All of the solder joints were staggered and covered in adhesive lined shrink tubing.
I estimated everything going into the rain tray would be about 32". Soldered all of the plugs into the lengthened wires then started wrapping the harness.
I was being OCD and depinning plugs to untangle the harness. Got everything as best I could, used the bends in the wiring to guide me how it was originally wrapped, then wrapped the half of the harness that would be in the car.
Everything that will be run in the fender well will need to be lengthened.
I really like this dry vinyl tape. The harness still remains very flexible, since there's no adhesive.
I wasn't thinking and ran the MAF plug into the rain tray.... Looks like I'll be unwrapping and lengthening.
The battery tray was pretty beat up and some of the spot welds failed.... pull it out. Having it out will ease making the holes for harness entry.
I'll need to fix one area, clean up some rust, then treat and spray some color in.
Not sure if the battery will be going back in this location. Thinking about some alternatives.
-Todd
ToddA1
NJ 08002
Unwrapped and rewrapped the latest harness to change the MAF plug routing. Luckily, all I needed to lengthen was 1 wire. This plug will somehow enter the rain tray on the passenger side.
Drilled out some spot welds to remove more engine bay brackets. May as well do it now, while engine isn't installed.
Filled the divots with some weld, and fixed the damage at the battery tray. The surface rust and welds got ground down and sprayed with some self etch primer. I'll spray color, later.
Also modified the bracket to mount the ECU.
The nuts are basically spacers. The upper screws were threaded in, so the ECU was a snug, slip fit. The screws were then welded. from behind.... they became mounting posts. I'll spray glue some felt to the bracket to keep the ECU from rattling.
The bracket uses 2 screws at the door jamb to fasten to the body. I planned on using a load of 3M double sided molding tape at the rear plates to fasten to the kick panel. I didn't want screws penetrating into the fender well.
The 2 screws at the bottom are still functional. With the ECU plug installed there's roughly .25" clearance at the top.
The plates should have had 2 nuts as spacers, rather than 1. It seems to work, so I'm unsure if I'll go back and correct.
-Todd
GEE-BEE
SO CALIF
1.9 AAZ
Harness / Custom - Plug and Play
http://fastforward.ca/standaloneharness/
mk1 jetta
new mk1 cluster with tach/ harness plugs into gas version cluster
ahu
gtb2265 turbo
rover 300 /giles mod
mk4 pedal
maf delete
erg delete
ecu tune
a/c delete
fan wiring delete
alh computer
colt stage 2
pauter rods
pd150 pistons
pd150 intake
custom girdle
I wanted plug and play and there pricewas fair
german cloth tape
I sent the complete harness for headlights. euro turn and city lights with it
ToddA1
NJ 08002
I'd took advantage of the warm weather and pressure washed the engine and trans. I didn't get a lot of pics...
My MO is blast the grease off with a turbo tip, then scrub everything down with gas. I don't think there's a cheaper or more effective degreaser.
Pulled all of the accessories off, then blasted the block again, to get the grease that was hiding. A lot of the parts that were removed took a bath in the parts washer.
There's a lot of build up in the intake ports, so I decided to pull the head... it got disassembled. It'll get cleaned out properly. I found the end of the cam was broken...
One of the coolant glow plugs broke during removal. I was staring at it for a bit and compared it to an IDI engine glow plug. Did some research and it turns out, it's the same. Coolant glow plug is to the right.
I need to place a parts order and get the head reassembled and back on the block. I want to get the engine in the bay, so I can figure out how much I need to lengthen the engine harness.
-Todd
ToddA1
NJ 08002
I pulled the valve stem seals and started scraping the soot out of the intake ports. Pretty impressed with the pile that I got out. I'll follow up with the torch, then port match.
Ive been soaking the intake valves (one at a time) in a can of gas, after scraping them with a razor blade. After 24 hours, I lightly chuck the valve into a drill and spin it against a razor blade, then steel wool soaked with gas. I'll lap the valves upon reassembly.
Placed a decent sized parts order and also ordered an engine stand. It's been a while since I had a stand. They're pretty handy until you're finished your project and tripping over it.
-Todd
dieseldorf
MA
ex- 1996 wagon, ex-2000 Jetta
Todd, this is one of the finest write-ups I've seen. Truly amazing! May God give you the will power to finish up this great project !! Good luck.
ToddA1
NJ 08002
That's a pretty humbling comment, with all of the great builds on here... thanks!
Tonight, the head got scrubbed down with gas, then took a bath in the parts washer. I can now touch it without getting black on me.
Any residual soot got torched out. I should have just torched it from the beginning. Came out very clean.
Surprisingly, the intake ports are pretty dead-on gasket matched. The exhaust ports are a different story. Probably wasting my time port matching.
My new trip hazard arrived today.
Need to get some long bolts and get the block mounted by the weekend.
-Todd
ToddA1
NJ 08002
Sealed up the head with plastic bags, Gorilla tape and butyl rope caulk. Cleaning aluminum chips and dust out of a head isn't fun.
The carbide burrs left a jeweled finish that I took down with 80 and 120 grit cartridge rolls. On the exhaust side, I probably could have left the jeweled finish.
On the intake side, I only wanted to get the heavy casting line off the sides of each port. I didn't want to disrupt the crazy swirl ramps. Likely wasted my time doing anything in these ports. I doubt I'll get anything from it.
I went into the bowl side very briefly with a 120 grit cartridge roll. There was a hard edge in each valve pocket, I wanted to soften.
I also got raped for bolts, for the engine stand. Want to get the block mounted tomorrow. I'm thinking of blasting the head and block, prior to painting.
-Todd
Steve Addy
Iowa
97 Mk3
Nice work!
Yes, the coolant flange GP's are the same as the old late IDI GP's (or early for that matter). I figured that out years ago when I had one on the Mk3 that needed to be replaced. Bentley suggests for Mk3 they have slip connections like the main engine GP's but I've never seen any out there like that.
Your neighbors give you any odd looks with that engine sitting out at the end of the drive? Where I live now it would be frowned upon, where I lived before no one would / did ever care.
Steve
ToddA1
NJ 08002
My street is somewhat U shaped. Being near the end, there's very little traffic.
Other than my crazy neighbor across the street, people don't seem phased. They've seen me doing this before, and most people just wave as they drive by.
I ported the head on the lawn, next to the Rabbit. I didn't want that mess in the garage. Roughly 4 hours of die grinding and no response from the neighbors.
Took it easy today. Got the engine on the stand, as planned.
Finally finished putting some color in the engine bay. Used an airbrush, so that little bit took some time. Cleaning the airbrush is a 5 minute affair, though.
Ended the day pulling the pan and random hardware off the block. Everything got the gas treatment, then a dip in the parts washer. I've been reusing the same gas and it's pitch black, but still cleans the heavy stuff with ease.
I'll probably let it settle for a few days then run it through a paint strainer.
-Todd
ToddA1
NJ 08002
Last night, I did a bit more work in the valve pockets. I wanted to get the ridge down a bit more. It's no longer bothering me.
Tonight, I pulled all the tape looking for any shavings. Perfectly clean inside which is good. Should have warmed the tape, though. It left a lot of adhesive behind which was murder to get off.
Retaped it, in preparation for the blast cabinet.
Been reading about blasting aluminum. I always get the dull blasted look. Started with walnut shell and that was getting me nowhere. Moved to glass bead at about 30psi.
Better, but still dull... I'll spray it with some self etch and cast aluminum paint.
My "blast in a bucket" gun arrived today. The block will get hit with some aluminum oxide.
Ordered some enamel hardener and found some green Rustoleum at work. Going for the OG VW diesel color scene. Undecided if I want to brush or spray.
-Todd
ToddA1
NJ 08002
Started prepping the block for paint. Pulled the oil pump, intermediate shaft and the filter flange, then chased every bolt hole.
Cleaned the block with gas, hosed it down with acetone, then taped it off.
Time to start blasting... Auminum oxide, 2 ladders, a 8' 4x4 and my leaf tarp worked excellent.
Tomorrow, it gets painted.
-Todd
ToddA1
NJ 08002
Getting ready for paint.
This is where it went bad. I didn't want to get the spray gun out, and figured the Preval would do an ok job. They don't lay down a great finish, but the block isn't smooth.
Preval couldn't spray the thinned paint. Started brushing, but the paint wasn't leveling out. Halfway through, I decided to cut my losses and stripped everything off.
That was enough. Packed it in for the day. Rattle can may be in the near future.
-Todd
ToddA1
NJ 08002
Lol. Yup, nothing involving me.... the crazy neighbors across the street.
I've never heard such a profane argument between a 75 y/o man and a 15 y/o teenager. I missed the first half, being behind the tarp and wearing sound canceling headphones.
Apparently, many people have issues with the loons across the street. Watching them can be quite entertaining.
-Todd
ToddA1
NJ 08002
Blasted more parts.
This daylight savings is killing me...
-Todd
Steve Addy
Iowa
97 Mk3
Yeah, I hate DST, I wish we'd just change it and leave it alone. I ride with several cycling groups and riding late in the afternoon is almost impossible now and it'll be getting even worse. Basically I'm less than thrilled about winter in general.
Steve
ToddA1
NJ 08002
Pulled the flanges and shift tower off the trans. Made a mess... I thought I drained the trans when the engine was pulled.
Trans got the gas and acetone treatment. Taped off then blasted.
Decided to give the block another quick dusting, because of the paint fiasco.
May be away from the project for a while. Home furnace went out again. Going to be some cold nights ahead...
-Todd
ToddA1
NJ 08002
Green. VW painted the earlier diesel blocks green. Unsure when they started or ended the practice.
Likely going to use Rustoleum aerosol. Don't want to get the spray gun out for such a small project.
-Todd
Steve Addy
Iowa
97 Mk3
I would have to say based on the amount of work you're putting into this thing you're planning on keeping this one?
It puts my B3V project to shame. I basically just washed all the gunk and sludge off the engine and that was it. The only reason I did that was so that I could see where any new leaks started...lol. Same with the trans too!
Steve
ToddA1
NJ 08002
I'm hoping to keep it. Only time will tell. I daily drove Rabbits for 20+ years. The only reason I bought the wagon and joined the forum in 08/2011 was because I needed air conditioning.
Pete at the body shop said I'll keep it less than a year, then sell it. I have a habit of doing this. Still on the fence about selling the wagon, but I need fuel prices to rise.
I've never blasted a block or trans before. From past experiences, paint always failed. Figured I may as well do the best that I could, short of full tear down and tanking.
Every project is a good one, no matter how much we bi*ch about them.
-Todd
Steve Addy
Iowa
97 Mk3
-Todd
I tend to agree, every project is a good, the complaining is just part of the process. If there weren't any complaints it wouldn't be any fun.
I'm not sure how soon fuel prices are going to rise TBH, and even then it's unclear whether the current emissions scandal will help or hinder the sales of the older tdi cars. There's a lot of floating oil storage out there right now and with China SPR just about filled there's some concern that we're going to see prices going lower...much lower.
I still think that in the grand scheme you can't go wrong with a wagon and that will always help prop up prices but I'm not sure we will ever see oil at $100 again or even $75 with countries pumping as much as they are now.
There's a recognition in the oil producing countries that constraining supply in an environment where 1) alternate energy sources are gaining ground 2) political leaders are denigrating fossil fuel (right or wrong) is not positive for the bottom line, and that's why we're now getting as much oil as they can get from the ground as quickly as they can get it out. Oil isn't worth much in a world where there's nothing but EV's regardless of whether the population (in the US) accepts them or not. I'm hoping a new course change is coming with the next administration. I have a feeling it is.
I know what you mean about the AC thing. My last project was converting the 89 Fox 2 dr to diesel and about two years later I sold it primarily because it lacked AC and the need for AC had become a big deal for me. Also because I can't get a road bike in the Fox and with the roof rack the Fox D lacked sufficient hp to move itself down the road with bikes on top in certain weather conditions (read wind). It was nice but not nice enough to keep so it went away while there was still a market for it, and it was clean.
At this point with your wagon I think it might be best to just sit and wait and see where we seem to be headed in 1Q 2017. It's been around long enough now that another six months won't make any difference.
I had promised myself last year that I would be rid of two cars and two motorcycles this year, unfortunately with my laziness I won't reach that goal. The truck might be gone before year end but I doubt that the diesel MB will be gone which was something I really wanted to have happen. Oh well, the list for 2017 will get some carryovers from 2016.
Steve
ToddA1
NJ 08002
Today, I blew out all the bolt holes and rechased them. Blew the block off then hosed it down with acetone.
Last time I stuffed all of the bolt holes with paper towel. That took forever. This time I grabbed used fuel line from the trash... just redid the fuel lines on the backpack blower. The larger hose fit the 8mm holes nicely. Stuffed it in, then cut it flush.
It's been in the 40°s. Too cold to paint, and the block needed to be warmed up. Let it cook for 2.5 hours, as I ran errands.
Made a quick paint booth. I knew those free Harbor Freight tarps would be good for something.
Rustoleum Industrial rattle can primer. 1 mist coat and 2 wet coats. 10 minute flash time, between coats. Cook box gets reinstalled after every coat.
I decided to use the original paint and hardener. 4 oz paint, .75 oz acetone and .25 oz hardner. Got the gun spraying how I liked, then 1 mist coat and 2 wet coats. 15 minute flash time, between coats. Cook box gets reinstalled after every coat. I'll let it cook on low overnight.
I'm used to Rustoleum staying tacky forever. It's already dry to the touch. I guess the hardener works...
The worst part.... 20 minutes cleaning a $10 gun...
Going to try and get some other parts painted tomorrow. I want to get this engine and trans in the car.
-Todd
ToddA1
NJ 08002
Started the day with garage organization... it was starting to get away from me. Doesn't look much different...
Blasted some more parts.
Blew them off, then hosed down with acetone. Needed to warm the parts up, in cook box V2.1.
The waiting rack and the spray booth. Rattle canning Rustoleum Appliance Epoxy. Been using this stuff for years... love it!
The parts will simmer on low, overnight.
-Todd
