Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old May 21st, 2013, 04:12   #31
03_01_TDI
Banned
TDI(s): Na
With older tdi you could idle off in first gear even up a hill. The hill assit hold doesn't release until x time has passed or if the fuel pedal is used. So I time my brake release early so the hill assist will release right when I idle off in first.
03_01_TDI is offline   Reply With Quote
Old June 7th, 2013, 12:37   #32
gmeyerga
Default stalling
I drove a new Peugeot 308 Diesel for a couple of months.
I did not stall once. That engine was incredibly smooth.
But even after 65K miles I still occasionally stall my 2011 Golf TDI
because I'm loath to shift into first while in motion.
gmeyerga is offline   Reply With Quote
Old June 7th, 2013, 16:41   #33
JaredC01
JaredC01's Avatar
I just killed mine about and hour ago pulling out of my driveway...
|DG Sigma 6 SSK||BFI Schwarz Knob||PolarFIS Advanced||Frost Heater|
|Pioneer 4000NEX||JL Audio 700/5v2||Polk Audio MM6501 x2||JL Audio 12w3v3-2|
JaredC01 is offline   Reply With Quote
Old June 7th, 2013, 17:11   #34
It's not the DMF: my '02 had a DMF (until it failed after 200K) and was impossible to stall. The hill hold can be a problem if you jump the gun getting moving. I do find it's good to let it come off before starting out.
But I think the big reason is emissions. These cars are tuned to give very little fuel off idle, making them easier to stall. And I think the non-Urea setup that's in the Jetta and Golf makes it worse. I think it also makes more noticeable the hesitation that people report starting out with the DSG transmissioned cars. The Passat with Urea doesn't exhibit the same driveability issues as a Jetta with a DSG.
And I think the heavier versions of the MKVI cars are tuned differently than the lighter ones, making them harder to drive without stalling. btcost here and I got our '12s at the same time, and he's reported that my 2 door Golf with no options is easier to drive than his Sportwagen. I think the JSW has to be tuned differently because it's 300 lbs. heavier. I also think this is why a tune helps. It adds fuel.
I have yet to stall my Golf.
2002 Jetta wagon, 384K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 260K; 2011 335d, 60K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old May 18th, 2019, 09:54   #35
Rotarei
Fuel Economy: 50 mpg average
Default Drive like a teen, not a grandfather.
Got my 2013 VW Jetta TDi Sportwagen almost 2 months ago. Never loved a car this much before. Have stalled it quite a few times. It's usually because I try and drive it as smoothly as possible and as easy on the clutch as possible. I do Lyft and Uber frequently, and most of my passengers can't even tell it's a stick. I pride myself on being a "driver", a "car guy", and an almost 20 year Master Mechanic veteran. So it does hit the ego a bit. Like 5 minutes ago at a red light, blasting Soundmurderer- Wired For Sound like a hoodlum, then promptly stalling when the light switched green. Embarrassing! Sometimes I even stall out going into 2nd at too low speed (parking lots) or decreasing too much speed while in 2nd gear. Guess I'm just used to my old Civics, could idle 450-500 rpm or so in gear without stalling. Anyway, this thread helped. I'll just be more aggressive and stop worrying about babying the clutch. Aka I'll start driving like I've got a pair.
Rotarei is offline   Reply With Quote
Old May 27th, 2019, 21:19   #36
iamatt
iamatt's Avatar
Fuel Economy: 45
I had to remove that annoying hillhold BS. You can with the vcds. Otherwise these clutches are pretty forgiving compared to some of my other cars I had with more cyl.
Sent from my FRD-L14 using Tapatalk
2014 Jetta TDI sedan (new) ,2014 TDI Jetta Sport Wagon 6MT (Flooded) Amsoil HDD3000 20K OCI, GSP Mod (RIP Rosie 4/4/2015), 2011 Toyota 4 Runner SR5 (Flooded), 2007 Duramax (Flooded), slightly modded GSPv2 is here, Bellatrix "Bella" Hunting God's County, katygsp.com
Amsoil Dealer -
http://www.texas-synthetics.com
iamatt is offline   Reply With Quote
Transmission Fluid Change - Automatic vs Manual Transmission tca32123 TDI 101 11 May 20th, 2014 18:32
2012 JSW manual Trans 2K miles hesitation... stalling XLexusTech VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 7 November 22nd, 2011 10:02
Manual stalling issue fixed on 2010 Jetta jajohn VW MKV-A5 Golf/Jettas 13 October 19th, 2011 16:45
ECU update available to fix manual stalling issue jajohn VW MKVI-A6 Jetta Sedan (~ 2011+) 4 June 1st, 2011 23:42
2009 Jetta manual stalling Jeffmx5 VW MKV-A5 Golf/Jettas 128 November 7th, 2009 06:17
Page generated in 0.15205 seconds with 12 queries
[Output: 77.92 Kb. compressed to 68.74 Kb. by saving 9.19 Kb. (11.79%)]
