Old May 16th, 2019, 15:01   #316
jimbote
jimbote's Avatar
Originally Posted by vwztips View Post
No need for G85 calibration
good to know, have you ever had the persistent 16955 code ? and if so, how did you solve it?
jimbote is offline   Reply With Quote
Old May 17th, 2019, 09:35   #317
jimbote
jimbote's Avatar
FIXED! ecm 94/65, ws/ro had gotten pushed out of the connector... code cleared and all switch positions in vcds are good to go*
Old May 17th, 2019, 09:37   #318
Sprocket
Sprockette's hubby
Sprocket's Avatar
Nice, good work!
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old May 17th, 2019, 09:39   #319
vwztips
vwztips's Avatar
Good to know. I have done over 30 conversions and had not seen that error before.
FWIW there is a different procedure if you have a Bosch 5.3 ABS
vwztips is offline   Reply With Quote
Old May 17th, 2019, 10:02   #320
jimbote
jimbote's Avatar
Originally Posted by Sprocket View Post
Nice, good work!
thanks! but i feel like a dope for not running this down sooner... i need to pay more attention to the label file next time
this is my FIRST B5.5 swap and i feel like every pitfall that existed i fell into... is the 5.3 procedure wildly divergent from the 5.7?
Old May 17th, 2019, 10:28   #321
vwztips
vwztips's Avatar
The 5.7 ABS you have to log in like you did and change the ABS code
The 5.3 ABS is just a straight soft code change with no log in required. However there is no corresponding soft coding for a FWD 5 speed. You have to code it as a 6 speed and IIRC AWD. Really don't know why it calls out a 6 speed specifically
Old May 18th, 2019, 18:15   #322
jimbote
jimbote's Avatar
long shot; does anyone have a clutch masters fx series on the shelf they could perform a quick measurement on and snap a few pics of ?
Old May 18th, 2019, 19:51   #323
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
I have a stock 240mm DMF and Sachs SRE on the shelf....
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old May 20th, 2019, 06:52   #324
blazen71
blazen71's Avatar
TDI(s): All Gone
I do. Txt me what you need. 262-370-9647
I'm your Huckleberry
blazen71 is offline   Reply With Quote
Old May 20th, 2019, 06:59   #325
vwztips
vwztips's Avatar
Is this a 4motion or FWD?
Old October 12th, 2019, 09:12   #326
Braddman
Fuel Economy: 6.4 L/100km mostly Highway
Post Custom pilot bearing
I found a great solution to the issue of not having enough transmission input shaft engagement in the pilot bearing. I bought an HK1522 (21mm OD, 15mm ID, 22mm long) drawn cup needle bearing and a 21mm OD, 15mm ID, 3mm width oil seal to keep the grease in the bearing and the dirt out. I got the seal and bearing from a local bearing supplier for about $7 each. The original pilot bearing is 16mm long with a built in oil seal which reduces the amount of the rolling element length to about 15mm. I took a piece of mild steel drilled it 20mm deep with an 11/16” bit bored it to 14mm deep about 20.95mm diameter (basically just a press fit for the bearing.) Turned a 45 deg. chamfer 4mm from the end of the bar stock to support the bearing inside the chamfer in the crank. I turned the diameter of the material to 0.25mm smaller than the flywheel bore which is around 35mm +-5mm (I don’t remember the actual size). I parted the bar stock off at 17mm long. This gives me 11mm of bearing engagement in the crank and 11mm in the bearing and seal retainer I made. The total input shaft support is about 14.5mm. I installed the oil seal with the numbers facing the bearing to prevent dust getting in the bearing.
Edit: I currently have 32000km on the pilot bearing with no issues.
Braddman is offline   Reply With Quote
Old October 15th, 2019, 13:29   #327
imo000
imo000's Avatar
Fuel Economy: Good enough
Is this necessary at all?
imo000 is offline   Reply With Quote
Old October 15th, 2019, 14:07   #328
GoremanX
GoremanX's Avatar
Depends, I guess. If you want to run a 240mm clutch and dual mass flywheel, then you need a 5mm spacer between the engine and transmission, which can reduce engagement in the pilot bearing to less than 3mm (not nearly enough). This solution would resolve that issue. In my case, I'm running a 228mm clutch and dual mass flywheel, so I don't need a spacer. That means my pilot bearing gets plenty of engagement. I recently inspected it after 2.5 years and 35k hard miles, and it's in perfect shape.
GoremanX is offline   Reply With Quote
Old October 15th, 2019, 16:43   #329
Uberhare
Uberhare's Avatar
TDI(s): Too many.
I drove mine for almost 5 years without issue. I still haven't taken the car apart yet, but it drove to its current rusting place.
Old October 16th, 2019, 13:07   #330
MILESB
Default 6 speed shifter assembly
Hi, does anyone have the part number for the 6 speed shifter assembly for the Passat auto to manual conversion
MILESB is offline   Reply With Quote
Planning 6-speed swap, so 5-speed swap is for sale Redneck Truck Private TDI Items for Sale/Wanted 0 February 13th, 2013 13:14
Coding/Login for BHW Manual Swap? alphaseinor OBD Scanners 2 August 10th, 2011 05:01
BHW Blown swap in another PD Engine? mogly VW B5 Passat TDIs 10 June 4th, 2010 12:31
BRM engine swap for BHW? TomB VW B5 Passat TDIs 31 October 28th, 2009 12:30
Does anyone know BHW manual trans swap FollowTheBlackRabbit VW B5 Passat TDIs 59 July 21st, 2009 10:33
Page generated in 0.18020 seconds with 13 queries
[Output: 133.26 Kb. compressed to 111.23 Kb. by saving 22.03 Kb. (16.53%)]
