Old December 6th, 2017, 16:25   #1
Drunkaroos
Fuel Economy: Avg. 40 mpg
Default Potential for a D24T swap?
Not really sure if this is the right sub-forum to post this in but...
Couldn't find any other threads on this so here goes.
Would it be possible to swap a D24T engine into an Mk5 jetta chassis? I understand I would need to make some drivetrain modifications, new transmission, etc.
Only asking because its either I do some sort of swap in the next few months or I rebuild the 300k km stock engine so that I can make some major modifications with less risk.
Thanks in advance.
Drunkaroos is offline   Reply With Quote
Old December 6th, 2017, 17:49   #2
crazyrunner33
crazyrunner33's Avatar
Anything can be done with enough time, money, and dose of insanity. What are your goals? And why does your engine need rebuilt? Mine has 305k km with around 185 hp and I wouldn't hesitate to use it for a higher power build.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Old December 6th, 2017, 18:05   #3
Drunkaroos
I wasn't planning on anything too insane. I actually wasn't aware that BRM tdi's could handle that much power with that high mileage
But my eventual plan was to build a pretty crazy Jetta, and I have read that the practical limit of the BRM without sacrificing the famous tdi reliability is around 250ps / 450lb/ft. I have seen some people running around 450ps / 700lb/ft on built D24T's (on forums, so I can't really verify the validity )
Also, the engine in my tdi was driven really hard its whole life (never warmed up properly, held at the rev limiter for inordinate amounts of time) so I really won't trust the structural integrity of most of the components until I actually have the time to tear it down to a bare block.
Old December 6th, 2017, 18:44   #4
narongc73
Or you could just buy a 335d and call it a day.
narongc73 is offline   Reply With Quote
Old December 6th, 2017, 18:50   #5
turbobrick240
turbobrick240's Avatar
I don't think a d24t would work transverse with front wheel drive. The I6 engine is pretty long.
Old December 6th, 2017, 20:15   #6
Drunkaroos
Oh. Is there any other turbodiesel engines (VW, Volvo, Mercedes) that would conform to the mk5 engine bay size? I'm not completely stuck on a D24T, if it doesn't work, it doesn't work.
Old December 6th, 2017, 20:17   #7
Drunkaroos
Unfortunately I really don't have the money to go out and buy one of those (high school student working part-time).
Old December 6th, 2017, 20:31   #8
turbobrick240
By far the easiest route would be to build your current motor, or a spare brm. I think you'd be pretty satisfied with 250 hp. Just tell your friends it has 450.
Old December 7th, 2017, 10:16   #9
crazyrunner33
Before considering an engine swap or anything big on your daily driver, you should watch the video in this Jalopnik article. Also, the swap they are attempting would be a lot easier than the swap you would like to attempt.
https://thegarage.jalopnik.com/the-t...ara-1748335994
There's cheap, fast and reliable, pick two. Mind you, it's also possible to pay a lot for something fast and it can still miss out on the reliable part. If you're eager to wrench and learn on a new project, I encourage you to do so. However, it's best to learn on a project beater car, not your primary source of transportation. I only say that because I've been there, done that and got the T-shirt.
Old December 7th, 2017, 10:30   #10
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Putting that 2.4L I6 lump in there would be like one step forward, and about five steps back. Seriously, not something you would want to consider. The BRM is a much, much better engine, simply due in large part to DI and EDC.
Why do you think it even needs to be "rebuilt"?
I think even your 300k km BRM even with a tune, starting now, against a BRAND NEW 2.4L IDI VAG TD (assuming we could find one) would outlive it.
oilhammer
www.cardocautomotive.com
Parts for the VW D24T/LT35 D24T Other VW Group TD(I)s 1 April 24th, 2015 13:45
Potential handling mod: Mk5 rear suspension swap bhtooefr VW MKVI-A6 Jetta Sedan (~ 2011+) 6 June 30th, 2011 18:50
trans code for potential swap 1towman VW MKIV-A4 TDIs (VE and PD) 0 March 17th, 2011 09:48
2002 Golf TDI Automatic for sale Abilene, TX - cheap engine swap potential teuton TDI Cars for Sale/Wanted 3 September 24th, 2010 18:54
Timing belt tension on Volvo D24T v8volvo Non VW Group Diesels 19 April 6th, 2009 16:04
Page generated in 0.16175 seconds with 11 queries
[Output: 97.66 Kb. compressed to 82.81 Kb. by saving 14.85 Kb. (15.21%)]
