Old December 5th, 2017, 11:11   #1
that tdi guy
Fuel Economy: 34 MPG
Question VagCom question
I just finished doing some vagcom stuff on my 2006 mk5 BRM. I was able to use vagcom to turn off my DRL, but when I tried to activate the comfort windows, it didn't work. I followed a procedure I found on myturbodiesel, and it just won't work. The one thing I can think off is that the back drivers side window doesn't work, so maybe the comfort windows won't work?
that tdi guy is offline   Reply With Quote
Old December 5th, 2017, 11:20   #2
goodmonkey
goodmonkey's Avatar
Are you trying to do comfort windows by key (in drivers door) or by remote? I know there are multiple check boxes to both inactive and activate based on what you are trying to do. Mine works, also a 2006 model. I think my remote battery is getting weak, because while I can unlock the car from a distance, I feel holding the button down to get the windows to roll down or up I have to be a lot closer, and may have to try a couple of times.
2006 Jetta TDI 5MT - 252k, 2007 Silverado Duramax - 419k
Previous TDI's: 1996 Passat TDI- totaled at 394k miles, 1998 Passat TDI - 175k miles, 2012 Passat TDI SE - 41k, 1996 Passat TDI Variant - 327k, 2014 Jetta SportWagon TDI 6MT - 29k, 2015 Passat TDI SEL - 18k
goodmonkey is offline   Reply With Quote
Old December 5th, 2017, 12:04   #3
that tdi guy
I am trying to do it with the remote, it could be that my remote batteries are getting weak. Also, after getting an aftermarket radio, my car no longer honks when it is locked. Any idea on why, and how to fix this?
Old December 5th, 2017, 14:00   #4
goodmonkey
goodmonkey's Avatar
No idea on why swapping the radio would change the ATA horn behavior. You could see if it is just the confirmation honk or the horn itself by using the panic on your remote or setting your alarm off. If only the lights flash then there might be a problem. Also, the alarm horn is controlled via CCM, the same module you were in looking at for comfort windows. You could look for fault codes there if you aren't getting the horn to work at all. I think that would be a good place to start, since you already have VCDS.
Old December 5th, 2017, 14:07   #5
crazyrunner33
crazyrunner33's Avatar
For the beep after locking, make sure that all the doors and trunk is closed, and try pulling on each door handle when the car is locked. If all doors are closed, then double check your VCDS settings and follow one of the tutorials for enabling and disabling the beep after the door. If the settings check out, then you'll want to test the triggers for all the doors. If there's a problem, a VCDS full scan should reveal a fault in one of the doors.
For the remote, try the VCDS tutorial again and double check the long coding and make sure the appropriate boxes are checked and unchecked.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Old December 5th, 2017, 15:13   #6
that tdi guy
It honks when the panic button is pressed. Thanks for the help guys, I'll look into it!
Old December 5th, 2017, 16:16   #7
goodmonkey
goodmonkey's Avatar
Great! Now you know it isn't the horn, but most likely a setting or one of the doors not locking/confirming they are locked.
Vagcom question mcyclonegt TDI 101 4 August 13th, 2011 16:09
Boost question + Vagcom tomtom1989 TDI Power Enhancements 2 October 9th, 2008 11:32
Yet another Vagcom question... mannytranny TDI 101 6 January 27th, 2004 16:39
VagCom Question itsmejerry TDI 101 2 February 27th, 2003 16:13
VagCom Question---> MCathcart VW MKIV-A4 TDIs (VE and PD) 7 January 22nd, 2003 09:27
Page generated in 0.12698 seconds with 11 queries
[Output: 80.24 Kb. compressed to 69.64 Kb. by saving 10.60 Kb. (13.21%)]
