need4speed
- Joined
- May 4, 2004
Just looking for opinions on what course I should take here.
1) I'm still working on swapping a head-gasket after an overheat. (head was slightly warped, has been repaired). (ALH engine).
2) When I was removing the EGR cooler from the turbo/exhaust fitting, one of the M8-torx bolts refused to come out and sheared. Since I couldn't get clearance to drill it, I had to pull the turbo. One of the exhaust-flange studs ALSO sheared. FML.
3) I was able to drill-out the EGR M8-torx bolt satisfactorily, once I got the turbo onto my workbench. Next to the cylinder head.
4) When I tried to remove the exhaust flange stud that broke off, the exhaust flange threads were damaged (I didn't drill perfectly straight). This turbo charger is a Garrett 17, not the normal stock 15. (probably doesn't make any difference here).
I can get a new M8 stud screwed back down in the hole, and the bottom 3 or so turns, it snugs down. But if I turn it about 3 turns, it wiggles. If I turn it another turn, I can just pull the stud right out of the hole. So, the top 7-8 threads or so are stripped, on one side of the hole. I tried cleaning them up with a tap, but it was no good.
So my options, as I see them:
A) I could just snug down the stud as it is, and it will probably hold.
B) I could drill-out the hole to the next size-up (M9), and thread it, and use a step-down stud like this: https://www.ebay.com/itm/SPECIAL-M9...914-T25-Late-Bay-Van-/380784727764?rmvSB=true ...
C) ... or I could drill it and use a helicoil, but will that work here with such a high-temp area? (I'm not sure - I've actually never had to resort to a helicoil before, never had to use one, I've always had good luck extracting broken bolts before now).
Advice?
Advice?
