Old November 30th, 2017, 07:13   #76
that tdi guy
Fuel Economy: 34 MPG
Originally Posted by crazyrunner33 View Post
The PD140 turbo is off an 8 valve PD rated at 140 hp engine with the BMM engine code, I believe it's a GTB1646v turbo. The GTB1749vc from Darkside if I remember right is a PD140 turbo with the CHRA swapped from a GTB1749vc off the 170 hp rated BMN 16 valve engine. The 16 valve engine's turbo is not a bolt on due to the manifold differences between the 8 valve head and the 16 valve head, hence why the CHRA is placed in the PD140.
The GTB1749vc has a slightly larger turbine wheel and compressor wheel than the GTB1646v.
Well, that makes a lot more sense, and clears up my confusion! Thanks
that tdi guy is offline   Reply With Quote
Old November 30th, 2017, 09:46   #77
crazyrunner33
crazyrunner33's Avatar
That might be the vacuum line coming from the EGR cooler. I'm not 100 percent sure because my EGR cooler magically fell off before I bought the car. If you deleted the EGR, then you'll need to plug the vacuum port that line would connect to. Below is an easy to follow vacuum diagram for our cars that sptsailing made.
http://pics.tdiclub.com/showphoto.ph...-color&cat=516
Also, do you have VCDS? It'd be interesting to see what the full readout shows.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Old November 30th, 2017, 10:02   #78
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Yeah, it looks like the hose that runs from #12 to #9
Still have the EGR (California)
I do have VCDS. The only codes I see for the engine are the smart actuator and cam sensor. The tune will take care of the actuator. I'm sure if the egr is supposed to have a hose connected it will pop up a code soon too. If you want the whole VCDS dump I can paste it here.
Wont be able to do anything more until I get off work. Will update later today
2004LB7 is offline   Reply With Quote
Old November 30th, 2017, 10:03   #79
that tdi guy
I've been considering replacing all the vacuum lines, in my car, due to some of them having been hodgepodged together, and making me get under the hood and clean everything up, and do a "wire tuck" job on it. That schematic is awesome.
Old November 30th, 2017, 21:06   #80
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
IT RUNS!
figured out the cam sensor. Torsion value was way off. Adjusted it little at a time until it started. Read the value and it was -6.something. surprised because I thought anything more than +/-5 it wouldn't start unless unplugged. Mine started with more then -6.
Anyways, adjusted it to 0.5
Starts and idles good. Broke in the new cam and took it for a test drive. First impression, feels like twice the power. There are a few spots where it feels like a dead peddle or major turbo lag, looks to smoke more then I would like right now but hard to tell because it is night and judging smoke in headlights behind me is very deceiving. Overall way better then stock. Sent a log to Malone. Will see how it is after some tweaks
Keep you updated
Old November 30th, 2017, 22:33   #81
crazyrunner33
Good deal! Sounds like you had a pretty smooth install and a good running car. Getting the engine to land above 1800 RPM on the gear change will allow you to stay on top of the turbo when you need the power, it should hit like a light switch above 2k.
Old November 30th, 2017, 23:47   #82
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Yes, there is a point where it seems to wake up. I will have to study it behavior and learn the best times to shift. Of course it is a DSG car so manually shifting is not always practical. I may need a DSG tune update to accommodate the new power band
Old December 1st, 2017, 07:07   #83
crazyrunner33
Mine is also a DSG. Sport mode works very well for the time being. When using drive you need to be a bit aggressive with the throttle to keep it from upshifting too soon. When getting on it in sport mode it pulls like a train to 4500 rpm. Applying a DSG adaption with VCDS may also help.
Old December 5th, 2017, 16:15   #84
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Played around with the torsion value (cam timing) to see if i can smooth out the idle more.
Adjusted it from -4.4 all the way up to +8.2 in small increments. Starts to smooth out around +3. Left it at +3.4
Also, I ordered a DSG tune update. Hopefully this will take car of the over rev neutral problem
Still waiting for an updated version of my tune based on the logs sent. Stay tuned
Old December 7th, 2017, 13:28   #85
hymato
Where are you getting the DSG tune?
hymato is offline   Reply With Quote
Old December 8th, 2017, 23:10   #86
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Malone
Old December 13th, 2017, 15:40   #87
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Got my 1st version of the DSG tune uploaded
1st impression, it certainly wakes up the responsiveness of the throttle. Revs quicker and thus builds boost faster. Much better driving manners. No real need to shift manually now.
Sport mode still needs to be addressed as it shifts way to high and hits the rev limiter
So far so good
Old December 14th, 2017, 11:59   #88
crazyrunner33
Glad to hear it's going well! I'd like to see a video if you can do so safely. I'm curious if my car has a DSG tune or not, since it came with an EGR delete and stage 1 tune.
Old December 14th, 2017, 14:02   #89
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
I'll see if I can get a video. What do you want, a shot of the cluster? From a stop to 60? 45ish to more?
Maybe I can get all. We will see.
Old December 14th, 2017, 14:37   #90
crazyrunner33
A shot of the cluster would be perfect, I'll show you mine if you show me yours. Acceleration to the speed limit and deceleration in sports mode would be cool to see how the downshifting is. My 2010 would engine brake on its own and downshift, the DSG in my '06 is nowhere near as intelligent.
2006 BRM - No Power Jaredmon VW MKV-A5 Golf/Jettas 9 December 21st, 2017 07:22
BRM power loss on highway chessmyantidrug VW MKV-A5 Golf/Jettas 12 May 13th, 2016 23:41
2006 BRM How much power? atstodd TDI Power Enhancements 11 January 15th, 2014 09:14
BRM power needs gilberjj TDI Power Enhancements 3 April 15th, 2010 01:04
BRM PD Power Options osomphane TDI Power Enhancements 16 October 17th, 2007 12:24
Page generated in 0.18377 seconds with 11 queries
[Output: 124.97 Kb. compressed to 104.43 Kb. by saving 20.54 Kb. (16.43%)]
