Old November 26th, 2017, 18:06   #61
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Originally Posted by scrambld View Post
PS: 2004LB7 I just want to experience a well responding BRM/PD140/Malone Stg4....living vicariously through you...LOL
Supposedly the GTB1749v is a better turbo then the PD140 turbo, same (or possibly better) spooling on the bottom end and more on the top end. Hope this is true.
I am going to run a stage 5 custom Malone tune. So I should be able to get what ever tuning adjustments I need to make it responsive and minimal smoke.
I am trying to maximize what I can get with this engine without going overboard and still keeping it as smoke free as possible.
I did run a stage 2 on my otherwise stock 09 CBEA and it was nice. Made driving a lot more fun. So this is really all I have to compare it to other than my stock BRM with a slightly worn cam. If my BRM beats my CBEA then I will call it a win
2004LB7 is offline   Reply With Quote
Old November 26th, 2017, 18:14   #62
scrambld
That's right...you're not running a PD140......still want to know how it is for you.....
scrambld is online now   Reply With Quote
Old November 26th, 2017, 18:32   #63
crazyrunner33
crazyrunner33's Avatar
The PD140 should have more bottom end than the GTB1749vc, the GTB should have more top end. I had mine actually detuned below 2000 RPM, it lights hard by 2300 RPM and pulls hard to redline. It makes around 175-180 hp in the real world with a gentle 250 lb-ft of torque.
My setup actually drives a lot like my 12 valve Cummins with a big turbo, on that one I have to shift at 3500-4000 RPM to land in the sweet spot on the upshift. Shifting like it's on the stock turbo results in a slow moving torqueless Honda experience. Most do not like it, but I prefer setups like this only because it's gentle on the driveline.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Old November 26th, 2017, 18:43   #64
lamboworld
Based on the wheel size I doubt there is much difference in spool, and there should be a few more whp from the 1749. I am curious if there is are any gains from the Colt stage 2 cam.
GTB1749v - 35.4/49
PD140 - 34.1/46
I am going to get my car on the dyno soon and I will post the results.
lamboworld is offline   Reply With Quote
Old November 26th, 2017, 19:28   #65
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Only a but dyno for me. I will let you know what it reads when done
I don't know how many photos I can get during the process as it will add considerable amount of time to document it and I won't have much before having to go back to work. I will get what I can
Had to work through Thanksgiving and the weekend. Supposed to get Tuesday and Wednesday off. We will see
Old November 27th, 2017, 07:05   #66
crazyrunner33
GTB1749v - 35.4/49
PD140 - 34.1/46
You'd be surprised what a couple mm increase can do. We replaced a 65mm inducer compressor wheel with a 67mm on my buddy's s400 and it completely killed his bottom end performance. It all has to do with the wheel profile, the way way it was made and the material. On the GTB1749vc it also receives a larger turbine wheel, the heavier material for turbine wheels usually results in a bigger difference when swapping out wheels in comparison to compressor wheels.
Old November 27th, 2017, 21:14   #67
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Got the head removed today, started at 5pm and finished at 8pm
Old November 28th, 2017, 07:31   #68
crazyrunner33
Good progress! How did the oil feed line removal treat you? It took myself a little while, but that's only because I'm not the sharpest pencil in the crayon box.
Old November 28th, 2017, 10:28   #69
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Getting it off the turbo was not a problem at all. Now I need to find out where the other end goes and undo the side. Looks like it runs around to the front of the block.
Is the breaded oil line supposed to attach to the same place?
Old November 28th, 2017, 11:11   #70
crazyrunner33
The oil supply line connects to the side of the filter housing. It's in a bit of a tight spot, removing it isn't difficult, getting the new braided line in without losing a waster was a bit of knuckle buster for my large and clumsy hands, George Carlin would be proud with my choice of words. Note the angles of the fitting on each side of the new oil supply line and make sure you're using the correct end.
Old November 28th, 2017, 11:29   #71
that tdi guy
Fuel Economy: 34 MPG
https://www.darksidedevelopments.co....o-upgrade.html
according to this, the pd140 is a gtb1749v?
I'm slightly confused haha.
I just purchased this kit. Excited to see how it does.
that tdi guy is offline   Reply With Quote
Old November 28th, 2017, 13:44   #72
crazyrunner33
The PD140 turbo is off an 8 valve PD rated at 140 hp engine with the BMM engine code, I believe it's a GTB1646v turbo. The GTB1749vc from Darkside if I remember right is a PD140 turbo with the CHRA swapped from a GTB1749vc off the 170 hp rated BMN 16 valve engine. The 16 valve engine's turbo is not a bolt on due to the manifold differences between the 8 valve head and the 16 valve head, hence why the CHRA is placed in the PD140.
The GTB1749vc has a slightly larger turbine wheel and compressor wheel than the GTB1646v.
Old November 28th, 2017, 21:26   #73
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Got most of it back together. Turbo, cleaned and installed the Head, Intake cleaned, new injectors, new cam, rockers, erc. Need to put the belt back on, finish putting all of the tubes, wires, 3 bar map sensor, etc back in.
Some photos to start
Gasket surfaces cleaned up
Head & Studs installed, ready for the nuts.
More photos tomorrow
Old November 29th, 2017, 19:00   #74
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Go everything back together. Thats the good part
The bad, getting a Cam code and no start. P3008. Is this related to the cam timing or is it a bad sensor? I did index/lock the crank and cam when putting it all back together. The cam bolts on the sprocket are about mid way
And I can't remember where this part goes. I am pretty sure it connected to the vacuum lines and ran behind the turbo to , maybe, the egr. Can't find any hose connection on the egr or around it.
Old November 29th, 2017, 22:54   #75
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
unplugged the cam sensor and it started. Hmm. Thinking the cam timing (torsion value) is too far off. Will double check the timing tomorrow
Hopefully Malone gets me my updated tune tomorrow so I can get this all done (as long as the cam sensor is fine)
2006 BRM - No Power Jaredmon VW MKV-A5 Golf/Jettas 9 December 21st, 2017 07:22
BRM power loss on highway chessmyantidrug VW MKV-A5 Golf/Jettas 12 May 13th, 2016 23:41
2006 BRM How much power? atstodd TDI Power Enhancements 11 January 15th, 2014 09:14
BRM power needs gilberjj TDI Power Enhancements 3 April 15th, 2010 01:04
BRM PD Power Options osomphane TDI Power Enhancements 16 October 17th, 2007 12:24
Page generated in 0.15851 seconds with 11 queries
[Output: 130.13 Kb. compressed to 109.10 Kb. by saving 21.02 Kb. (16.16%)]
