Old November 20th, 2017, 12:30   #46
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
I purchased the ARP 202-4303 set. I'll need to machine down the nuts to clear the caps.
2004LB7 is offline   Reply With Quote
Old November 25th, 2017, 00:47   #47
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
This showed up today
Old November 25th, 2017, 00:47   #48
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
ARP studs are supposed to arrive tomorrow
Old November 25th, 2017, 05:39   #49
scrambld
Get it done already. I am wanting to know your results. I wasn't so happy with mine....I believe I still have an undiagnosed issue with mine from the get go.
scrambld is online now   Reply With Quote
Old November 25th, 2017, 08:16   #50
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Did you run some logs and have Mark look it over?
Old November 25th, 2017, 16:21   #51
scrambld
Yes, per them nothing out of whack (and 4 other local TDI gurus from this site have been thru this car). I was MUCH more impressed with the Malone Stg2 and stock turbo ....by a lot (VR6 clutch had already been installed). That setup flat out smoked the present setup...wish I had the original "broken" turbo back. SERIOUSLY! Turbo came from Kerma, so unless something was amiss with the "new" turbo I am at a loss as to why it won't perform...?
PS. Search for my previous post regarding this issue, as far as I can tell every leaf has been turned over. I am SURE something has been over looked...
Old November 25th, 2017, 18:48   #52
lamboworld
I have the PD140 turbo with a Malone Stage 4 tune and it is significantly faster than my previous stock turbo Malone stage 2 tune. I suspect that have something wrong.
lamboworld is offline   Reply With Quote
Old November 25th, 2017, 19:08   #53
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Got my studs in finally.
Chucked the nuts up in my drill and ran a file over them. Now I need to see if they fit
Old November 26th, 2017, 05:55   #54
scrambld
I agree 1000%.......but after 4 TDI masterminds couldn't figure it out I've given up hope.....I'm reminded of how underpowered/laggy this thing is every time I drive it.
OP, carry on and enjoy!
Old November 26th, 2017, 06:30   #55
lamboworld
I am going to make a suggestion. I doubt very seriously if you have had 4 TDI pros look at your car that your issue is with anything mechanical. I suspect that you have an issue with your tune. If I were you, I would have my car reflashed.
I originally had a Malone 1.5 tune and when I sent my ECU to Andrew they accidently flashed their stage 2 tune and it ran like ****. After multiple conversations with Andrew Rodriguez he figured out that my car did not have the correct tune. You could run a few logs if you have VCDS that might help figure out if your problem is tune related but I suspect that it is.
Sorry to get off topic OP.
Old November 26th, 2017, 11:25   #56
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
As long as it stays civil and doesn't turn into an internet brawl I am OK with it. It is at least mildly related though
Old November 26th, 2017, 12:21   #57
hymato
Where did you get your injectors and how did you set the lash?
hymato is offline   Reply With Quote
Old November 26th, 2017, 12:42   #58
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
Nothing is installed yet. Too many hours at work.
My understanding is that injector lash is set with a dial indicator to find when the injector is fully pressed, bottom out the adjuster screw and then back it out 180*
If all goes well I will attempt to install on Tuesday and Wednesday
Old November 26th, 2017, 15:40   #59
scrambld
Yes, 4 TDI pros....all from the forum here.
3 Malone tune adjustment trying to resolve the issue and 1 TDtuning tune all without remedy.
I won't say it is a not a tune issue but they do know their tuning....
PS: 2004LB7 I just want to experience a well responding BRM/PD140/Malone Stg4....living vicariously through you...LOL
Old November 26th, 2017, 16:20   #60
crazyrunner33
crazyrunner33's Avatar
Scrambld, how does your car run on the top end, or from 2 grand and above?
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
2006 BRM - No Power Jaredmon VW MKV-A5 Golf/Jettas 9 December 21st, 2017 07:22
BRM power loss on highway chessmyantidrug VW MKV-A5 Golf/Jettas 12 May 13th, 2016 23:41
2006 BRM How much power? atstodd TDI Power Enhancements 11 January 15th, 2014 09:14
BRM power needs gilberjj TDI Power Enhancements 3 April 15th, 2010 01:04
BRM PD Power Options osomphane TDI Power Enhancements 16 October 17th, 2007 12:24
Page generated in 0.16770 seconds with 11 queries
[Output: 127.70 Kb. compressed to 106.90 Kb. by saving 20.80 Kb. (16.29%)]
