Old March 14th, 2017, 13:42   #1
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
Default Roll center on DRVOLKS.com Chump/Lemon Beetle
OK I had a snow day today and had time to test my Beetle Chump/Lemon roadracer Beetle/
So the car is one of the fastest TDI Beetles around .
Below is Roll Center software used to find it on any car and what to do to get it right.
My car as it sits my rollcenter is on the top of the pavement far from the best place. The lower the car gos the worse it gets it is below the ground 2 inchs for every one inch of downward movement. I run my car high in the front to help it handle with the setup we have hear.
The only place with this front end to get it right is to move the ball joint and the inner a frame pivots, but I need to drop the front end to to lower the center of gravity of the car too.
So now the hard part we will need to relocate the a frame inner pivots after we lower the car 2 inches . Then build lower ball joints with a 1.5 inch longer stem.
The sweet spot is 3 inch above the ground at race ready and as the car dives under braking and turn in the turn to keep the roll-center above ground.
It would be best to have it not move but with the car VW design your will never get there.
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old March 14th, 2017, 13:47   #2
GoFaster
Moderator at Large
Oh fun.
You'll have to play around with the steering rack location to address bump steer, too.
Why are the L and R RCH different even though (unless I'm blind) all the input dimensions are the same?
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old March 14th, 2017, 14:45   #3
CNGVW
I did a post on that last year have the bump steer plate on hand for later .
I may have loaded a number and did not refresh??
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
1998 VW TDI Beetle DRVOLKS Racing car for sale $4950 CNGVW TDI Cars for Sale/Wanted 0 October 25th, 2016 18:24
DRVOLKS.com entered in NH Lemon race CNGVW TDI Motorsports 6 October 25th, 2016 08:51
Chump Cars at VIR 1854sailor TDI Motorsports 5 August 12th, 2014 11:50
WTB Center armrest in black for 02 TDI beetle and center console pieces xhaus11 Private TDI Items for Sale/Wanted 0 January 21st, 2010 09:18
window roll up / roll down on 02 jetta tdi or 00 beetle TurboBugger OBD Scanners 6 November 6th, 2009 09:02
Page generated in 0.12477 seconds with 11 queries
[Output: 59.68 Kb. compressed to 54.29 Kb. by saving 5.39 Kb. (9.03%)]
