Emily
I have a 2003 VW Jetta TDI station wagon. I have 79K miles on it and need to get my 80K tune up. The dealer said that I should get my timing belt changed at 80K; they quoted $1000 but didn't mention changing the water pump. I called another shop and they said I didn't need to do that until just under 100k (I have checked and I do have the 100K timing belt). The non-dealer shop that I spoke with sounds great, but they are turning out to be just as expensive as the dealer, if not a little more. They quoted something like $1200 when I do need to get my timing belt/water pump changed. They are charging just under $400 for my 80K tune up, which is basically an oil change plus air filter replacements (cabin, engine, fuel). My buddy in Idaho, who does all of his own TDI maintenance, thinks these prices are totally outrageous. Is this standard pricing for Seattle? Does someone know of a great TDI mechanic that is reasonably priced? I have been using one of the VW dealers as our mechanic and would like to switch.
Thanks!
Emily
Thanks!
Emily
