Yes, last year's winter was brutal. Frost 8 feet deep & 7 months long. At least when it's that cold it doesn't snow as much.
I cover my "custom" piece of 3/16" thick cardboard with black Gorilla Tape to keep it from getting soggy in the car wash, then when I take off the winter wheels & I remove the bumper cover again and take it out for next year.
Tried the pipe insulation, this works better IMO. I also block off the intercooler grille with a solid backed grille from a 2.SLOW. I'd rather conserve as much heat as possible in the intake, IAT temps observed significantly warmer when it is -35C or lower like it was a couple mornings last year.
The OBD dongle + Torque app, best $25 I've spent, turns guesses into tested solutions.
Usually, with a coolant heater plug-in for 4 hours prior to leaving in the morning, -30C temps, I'm at 90C in 10km (6.2 miles) driving at 110km/h (~2400rpm, 5spd).
No overheating in 20C temperatures, although we don't exactly have a ton of stop & go. I wouldn't try running the A/C at all with the condenser blocked off though.
