charlie75
Well, it's happened to me! I've done the forum searches and it doesn't look good!
I have a 2000 NB with 135K miles and an automatic transmission.
I have had the numerous small problems that most have. The engine, however, has run flawlessly; 100K timing belt and transmission serviced at 110K by a TDI guru. I have used only VW automatic transmission fluid!
Last night after spending about 1 1/2 hours in DC stop and go traffic, (the chief reason I drive an auto!) I noticed that the AT was not shifting into the top gear. (Top speed 60 mph at 3000 rpm). Got home, restarted the car, test drove it to discover that the AT would not shift into the 3rd or 4th gear. (Top speed 40 mph at 3000 rpm). Also, I now had a "Check Engine Light".
I do not have a Vag-com, but will work this weekend with a friend with a OBD code reader. I'll let you folks know what codes that I find.
Opinions? (I know it's premature without those codes)!
