So My prodject is to take a 1968 VW early bay T2 VAN and install a 1900 TDI AFN engine in it.
After plenty of reading ive desided to go with the throttle by wire method. if anyone can lay there hands on a pinout or wiring diagram for the ecu... that would help a great deal
The engine is from a passat 98 ish a 110bhp afn.. im going to mate it with a purpose built high ratio box. Anyone know of any adapter plates available to make job easy... I know about the derv bell housing from a t25 method which i will use unless adapters are available.
Anybody have any suspension mountings... specs, changes i need to make???
