Old January 23rd, 2018, 11:07   #1
Aato
Default Passat B6 US lights
Hey guys, does anyone know how to enable US running lights function via VAGCOM. I'm in Europe and I've seen a few passats around with them I'd assume this is normal on your cars in USA but here its not heres a picture for reference
Here in Ireland our turn signals are completely off until your turning and switch one on but US lights allows the amber to be on constantly and when turning they flicker as usual. Its the light in the bumper above the fog light area.
Aato is offline   Reply With Quote
Old January 23rd, 2018, 12:30   #2
20IndigoBlue02
20IndigoBlue02's Avatar
It should be in the CECM module, for North American DRLs.
If you have a VCDS, you have 2 options for DRLs, well technically 3.
1) North American DRLs (low beam at reduced PWM)
2) Scandinavian DRLs (low beam and exterior lights on)
3) Fog lights as DRLs.
The NA DRLs will also affect the behavior of the light switch, so in the middle position, it will be the DRLs that stay on, instead of the running lights.
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old January 23rd, 2018, 12:48   #3
Aato
Those lights above the fog grills are they parking bulbs, meaning they stay on with dip lights and headlights or are they the turn signals? I bought my Passat recently and I haven't really checked it out yet. All I know is I want them Orange like the picture!
Old January 23rd, 2018, 13:46   #4
20IndigoBlue02
They are turn signals.
You can make the turn signals on with the corner marker lights, using VCDS. But the H21W bulb will get hot and start melting plastic, so you can dial down the intensity for it.
It's in VCDS.
Old January 23rd, 2018, 13:53   #5
Aato
It's in VCDS.
I've watched a few videos on how to do it now, what percentage do you think would be best it goes from 0-100% right? The higher the percentage the brighter it is and most likely the hotter it gets. Also I have to pick up VCDS, is it just the software and cable and it can work off any normal laptop?
Old January 23rd, 2018, 15:01   #6
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
I have to laugh, there are so many on this board from the USA who want to delete the DRL's, which are a safety feature for you to be seen.
Now along comes a member from Ireland who wants just that feature, congrats bud!
Incidentally one way I identify police cars on the highways or in town is that the do not use DRL's, though the new Dodge Charger models may be different.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Jetta_Pilot is online now   Reply With Quote
Old January 23rd, 2018, 19:02   #7
20IndigoBlue02
Yes, VCDS cable and a regular windows laptop.
10% is a good amount.
Old January 24th, 2018, 05:21   #8
Aato
Lol its pretty big over here a lot of people run US lights mostly on German vehicles not so much Jap. I think it looks great too.
Thanks indigo I'll definately pick up VCDS soon and give it a go.
Old February 24th, 2018, 11:27   #9
Aato
Sorry to bring up an old thread but I might be activating this tomorrow as I have use of VCDS from someone. What's the highest percentage I could go with the lights without having the possibility of them melting the plastic? What is the default percentage for your cars in USA? Also I see people driving around with them here and they are probably much brighter than 10%.
Old February 24th, 2018, 14:58   #10
20IndigoBlue02
the default percentage is zero, as it's not used as a running light.
the highest without melting? You'll have to experiment and find that out.
B6 Passat? 1854sailor TDI Conversions 13 October 29th, 2015 11:34
FS: Passat CC TDI cluster - White display - to fit Passat B6 Jarek Private TDI Items for Sale/Wanted 2 December 28th, 2011 12:08
Door Courtesy Lights Retrofit B6 Passat mercedeslimos Upgrades (non TDI Engine related) 4 December 4th, 2011 07:58
Passat B6 Max4ever Passat TDI Picture Gallery 1 January 6th, 2009 17:46
Another B5.5 Passat or RISK waiting for B6 Passat tdireader VW B5 Passat TDIs 19 March 15th, 2005 19:19
Page generated in 0.16052 seconds with 13 queries
[Output: 100.33 Kb. compressed to 85.38 Kb. by saving 14.95 Kb. (14.90%)]
