Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old December 10th, 2004, 22:38   #1
cawfebug
Default Cold weather hesitation with BD
Hello - I have been using B20 for a year and 1/2 in a 2003 Jetta Wagon. I live in Michigan. The other day I put in a full tank of B20 (winterized to zero). Two days later, I stopped by to add B50 (Ultra low sulfur 15 bbm) about 1/4 tank of that. I am sure they said that was winterized to zero as well.
The temp yesterday was in the 40's, however tonight it got down to 32-34. We went out, parked the car out in the cold (snowing). When I started off in first it seemed to hesitate, didn't have any power, same in 2nd, third, but 4th was ok at slow speeds.
I really started to notice it while getting onto the freeway - and going up hill, it really started to loose power. I made it home luckely ... about a 30 mile drive.
Can anyone share their experience with this? Is this a classic example of non-winterized fuel?
When I got it in the garage, I thought I would take a look at the fuel line (as if I would know what to do or know what to look for - and I saw a fairly long air bubble about 1.5 inch - I am pretty sure small air bubbles are fine, but nothing this big - could this be the issue or is this typical? I just got the fuel filter replaced about 2000 miles ago.
If it is the BD what should I do? add an additive or isn't it too late.
thanks for you help.
cawfebug is offline   Reply With Quote
Old December 10th, 2004, 23:45   #2
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
Fuel Economy: 57/43/32
Look here.
jackbombay is offline   Reply With Quote
Old December 11th, 2004, 16:28   #3
BeetleGo
Pre-Forum Veteran Member
BeetleGo's Avatar
Fuel Economy: 39/46, usually 41
Key word in your entire post was GARAGE. After leaving it parked in your garage and starting it back up again, did the symptoms persist???
If they did, you can be sure it wasn't the fuel.
BeetleGo is offline   Reply With Quote
Old December 11th, 2004, 16:45   #4
nh mike
Default Re: Cold weather hesitation with BD
a large air bubble in the line from the filter to the pump can be a result of the filter being partially clogged from unwinterized fuel. As the fuel warms up, and the filter clears out, see if the air bubble disappears.
nh mike is offline   Reply With Quote
Old December 11th, 2004, 18:47   #5
cawfebug
The garage isn't very warm - but probably above 40. still have a good sized air pocket in the fuel line (see photo). I haven't driven it today.
Old December 11th, 2004, 19:33   #6
BioDiesel
TDI(s): '98 Jetta
B100 or winterized fuel performs the same until it gells. At which point you go nowhere.
Significant performance loss would only result from a fuel restriction, not chemical diffrences. The bubble is evidence of a restriction.
BioDiesel is offline   Reply With Quote
Old December 14th, 2004, 21:33   #7
cawfebug
The dealership said that the air bubble in the clear fuel line is normal. They told me to use One Shot diesel additive. so I put that in - but the car is still hesitating/stalling over 40 mph. push down on the pedal and nothing happens. Geez - you would think they would winterize B50 at this time of the year!
Old December 15th, 2004, 11:16   #8
rdkern
Fuel Economy: A4 = wife drives it, don't know
When did you last change the fuel filter? Your symptoms could be caused by a clogged filter.
rdkern is offline   Reply With Quote
Old December 20th, 2004, 04:37   #9
cawfebug
changed fuel filter about 2000 miles ago - It runs fine for about 10-15 min. in this cold weather, then it starts hesitating - mostly in 2nd and 3rd gear when you are pressing down on the gas pedal.
Old December 20th, 2004, 05:36   #10
RC
RC's Avatar
.... pressing down on the gas pedal.
I don`t beleive you have a "gas" pedal in your TDI.
RC is offline   Reply With Quote
Old December 20th, 2004, 18:17   #11
cawfebug
how true... should I say turbo pedal? or that rectangleish thing on the right that makes the car go
except mine isn't goin'n very far in our 10 degree weather.
Page generated in 0.15155 seconds with 10 queries
[Output: 94.17 Kb. compressed to 79.17 Kb. by saving 15.00 Kb. (15.92%)]
