Old April 20th, 2003, 19:42   #1
oldpoopie
oldpoopie's Avatar
Default need complete brake fluid swap procedure.
Hi all.
I was looking in the bentley and couldnt find the info on brake fluid change. I plan on completely flushing everything, including the abs and clutch. Anyone able to give the appropriate directions or link to such, will be greatly appreciated.
Old April 20th, 2003, 19:52   #2
Birdman
Fuel Economy: 55 summer 50 winter
The Bentley CD has the directions on all that. But it won,t let you cut and paste them. You also need the Vag-com to do the ABS module
Birdman is offline   Reply With Quote
Old April 20th, 2003, 19:53   #3
Fast_SilverTDI
Fuel Economy: 5.6/100
It's really simple. To bleed your brakes, simply start with your passenger rear wheel, driver side rear wheel, passenger fr then drivers front, then clutch. When you're pumping the pedal, make sure you put a block of wood under the brake pedal so you don't push it past what you normally would with regular braking. This will prevent damage to the master cylinder by dragging crap on the piston through the seals. Then bleed your clutch. Make sure you DO NOT use DOT 5 fluid. You'll destroy your braking system by doing so. You might want to buy yourself a one man bleeder kit. It's a check valve that allows you to push fluid out but it won't allow any air back into the lines. This way, you don't need 2 people to do the job. Also, most importantly don't let the resevoir empty out otherwise you'll have to re-bleed all your calipers and clutch again because it'll let air into the system. Always keep it topped right up!
Good luck
Fast_SilverTDI is offline   Reply With Quote
Old April 20th, 2003, 19:58   #4
Birdman
IF you allow one part of the resevoir to run dry YOU have to Bleed the ABS module according to the bentley CD. The Vag-com runs the ABS unit while you bleed both front brakes at the same time and gets any air trapped in the ABS pistons out.
Old April 20th, 2003, 19:59   #5
oldpoopie
oldpoopie's Avatar
right, I have the vag-com, an oil extractor, and its associated brake fluid vac-bleed attachment.
I guess what I want to know is, when do I do the abs pump, before I do the front brakes, after the back brakes, and before the clutch, or what?
Old April 20th, 2003, 20:02   #6
oldpoopie
oldpoopie's Avatar
nevermind, we must have posted at the same time birdman. So let me understand.... I bleed the back brakes, then the abs which will in turn bleed the front brakes, then the clutch.
Correct?
Old April 21st, 2003, 11:34   #7
Birdman
IF you want to BLEED the abs pump you need a vag-com no way around it. you should also have the Bentley CD which explains in detail haw to to it. I can't print and fax the info or i would. When doing the pump you do BOTH front wheels at the same time then do the RT rear, LF rear. RT front ,LF Front, just like any car normal. As stated above you only have to bleed the ABS unit IF the reservoir has been empty.
Old April 21st, 2003, 12:28   #8
Dean_S
Bleeding the brakes is something most folks don't look forward to. But you can get much of the benefits by removing the fluid at the reservoir and replacing once a year. These euro designed systems with reserviours vented to atmosphere suck. Thats how moisture gets in and the most moisture contaminated fluid will be in the reserviour. In any case, you should do this before bleeding, as this will prevent pumping the worst through the length of the system. If you want to get extreme about it, you can empty it, then force the caliper pistons back and emtoy again. With the rear brakes you would have to remove the pads and use the proper tool to get the piston back in, and that is probably too much unless you are replacing the pads anyways.
And don't forget that block of wood behind the brake petal!!!
Dean_S is offline   Reply With Quote
Old April 21st, 2003, 12:44   #9
cosmic
cosmic's Avatar
Fuel Economy: 53/42/38
Brake fluid change link
I did not bleed the ABS unit. Just the 4 corners and the clutch.
Good luck.
cosmic is offline   Reply With Quote
Old April 21st, 2003, 18:21   #10
jettajim
Fuel Economy: 6spd=46 lifetime, '12 Passat gasser-terrible
Everyone: look at the Bentley. The brake lines from the wheels go thru the ABS and then to the res. OK, now what happens to the fluid in the res as you suck it out of a brake line? The res fluid drops. This simply means that when the car is off, the ABS is a straight thru by-pass to the res. Another meaning of this setup is this: when you bleed the brake lines, you are also bleeding the ABS. The only thing you need the vagcom for is if you actually replace the ABS electronic module (this is secured to the hydraulic unit) and only to code the unit to communicate with the ECM.
Do as someone above stated and drain the res (but not dry of course) first before bleeding the brakes. Fill it up with fresh DOT 4 and begin. It's just like any other car.
edited for this info: I have tried several different 1-man brake bleeders and they all suck (well, not really, they're just not worth the time or money). Bleed them the old fashioned way--with 2 people. It's MUCH faster and not nearly as messy!
Another item cosmic's post reminded me of is the clutch. You might as well do this at the same time since you're already in there
jettajim is offline   Reply With Quote
Old April 21st, 2003, 19:07   #11
Birdman
[b] oldpoopie asked for the proper way according to the bentley to bleed the ABS , brakes , and clutch. I have tried to relay that. oldpoopie I have bleed the ABS the proper way many times and if it were my car Leave it alone UNLESS one of the chambers on the resevoir goes dry. I would get as much out of it and fill with fresh before starting. You may find the Information on Bleeding the ABS unit under 01 On Board Diagnostic (OBD),ABS ITT Mk 20 IE On Board Diagnostic (OBD) program. Not under brakes on the CD bentley. It may be in the same place in paper version. Sorry for the bold don't know why it did that.
Old April 21st, 2003, 19:48   #12
oldpoopie
oldpoopie's Avatar
well, here is the deal, back in the fall, when I did the vr6/1.8t front brake swap, I bled the brakes, but didnt know what I was doing, and the res went dry, so yes, I got that gurgle gurgle sound.....
Yes, I am a stupid man.
Now to the point, I want to... have to do a complete brake flush, and since I did such a bad job last time and my pedal feel is so crapy, I want to do it complete and by the book. Thanks for the info birdman, much appreciated. I should have the super blue by friday, so I'm hoping to do this next monday.
Old April 21st, 2003, 20:03   #13
Birdman
Note long post. Hope this comes through so if you can,t find it in your paper Manuel you will have some idea what to do and why you need the Vag-com. The Vag-com will walk you through it just keep hitting the up button after each time you go through the process.
Basic setting, initiating
Special tools and equipment
V.A.G 1869 Brake filling and bleeder unit
Function 04 "Initiate basic settings" performs several functions:
Display group 001 is required to bleed the hydraulic system Page 01-91
Note:
The basic setting to bleed the hydraulic unit is only required when one chamber of the brake fluid reservoir is completely empty.
The basic setting is used to bleed the hydraulic unit only. The brake system must be bleed separately.
Repair Manual, Brake System, Repair Group 47
01-92
Display group number 01: Bleeding hydraulic unit.
Note:
All functions which could previously be performed with V.A.G 1551 can also be performed with the tester VAS 5051.
- Connect brake filling and bleeder unit V.A.G 1869.
- Connect V.A.G 1551 Scan Tool and select (address word 03) "Brake electronics" with ignition switched on; Page 01-23
Rapid data transfer HELP
Select function XX
Indicated on display
- Press keys 0 and 4. (The function "Initiating basic setting" is selected with 04).
Rapid data transfer Q
04 - Basic setting
- Confirm entry with key Q.
01-93
Basic setting HELP
Enter display group number XXX
Indicated on display:
- Press keys 0, 0 and 1
System in basic setting 1
Depress pedal and hold...
- Operate pedal with substantial foot pressure and hold.
Pedal moves down
Hydraulic pump runs
Pedal comes back
Rel. pedal; FR/FL bleed screw OPEN <3>
- Press key 3 on VAG 1551 or arrow up key on VAS 5051.
System in basic setting 2
Please wait...(10 secs.)
Hydraulic pump runs
Depr. pedal 10X; bleed screw CLOSED <3>
01-94
System in basic setting 3
Pedal moves down
Hydraulic pump runs
Pedal comes back
System in basic setting 4
Hydraulic pump runs
01-95
System in basic setting 5
Pedal moves down
Hydraulic pump runs
Pedal comes back
System in basic setting 6
Hydraulic pump runs
01-96
System in basic setting 7
Pedal moves down
Hydraulic pump runs
Pedal comes back
System in basic setting 8
Hydraulic pump runs
01-97
System in basic setting 9
Pedal moves down
Hydraulic pump runs
Pedal comes back
System in basic setting 10
Hydraulic pump runs
01-98
System in basic setting 11
Pedal moves down
Hydraulic pump runs
Pedal comes back
System in basic setting 12
Hydraulic pump runs
01-99
System in basic setting 13
Pedal moves down
Hydraulic pump runs
System in basic setting 14
Hydraulic pump runs
01-100
System in basic setting 15
Pedal moves down
Hydraulic pump runs
Pedal comes back
System in basic setting 16
Hydraulic pump runs
01-101
System in basic setting 17
Partial bleeding ended
- Press key.
Select function XX
- Press keys -0- and -6- to end output.
06 - End output
- Confirm entry with Q key.
Rapid data transfer Help
Enter address word XX
- Press C key.
- Switch ignition off.
- Disconnect connections to V.A.G 1551 Scan Tool.
- Bleed brake system.
Repair Manual, Brake System, Repair Group 47; Bleeding brake system, vehicles with and without ABS
Old April 21st, 2003, 20:04   #14
jettajim
birdman, so what's the proper way to bleed the ABS? I read my paper Bentley and read nothing about specifically flushing the ABS unit. They only mention having to use a vagcom when switching units--and that's only to code it. Am I missing something?
Thanks,
Jim
Old April 21st, 2003, 20:09   #15
jettajim
I wrote my post during your last post. Thanks for the info!
Page generated in 0.18405 seconds with 10 queries
[Output: 132.05 Kb. compressed to 112.07 Kb. by saving 19.98 Kb. (15.13%)]
