Old July 29th, 2015, 12:28   #16
3L3M3NT
3L3M3NT's Avatar
I'm all set to put the brakes on the car now that I got the rear calipers back from Espos Powdercoating, who color matched them to the special order blue that the fronts are. All I have to say is they turned out phenomenally!
Check him out at: http://espospowdercoating.com/
Here are a few pictures of the calipers to show you the quality of his work.
With some help of a few friends, hopefully the brakes, wheel studs, and wheels will be on the car so it can be rolled around, since there's no seats in it. lol
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
October 19th,2019 Cruise/GTG in Sturgeon Bay, WI
3L3M3NT is offline   Reply With Quote
Old July 30th, 2015, 06:16   #17
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
Looks good, did you or the PC guy take apart the rears?
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Old July 30th, 2015, 08:37   #18
3L3M3NT
3L3M3NT's Avatar
Since I'm unable to take them apart I had a friend take the calipers apart. He's actually going to be re-assembling the rear calipers over the next few days, so I really want to get the brakes on.
Firefox fix
RTDI Build Thread
Old July 30th, 2015, 08:54   #19
Nash_TDI
Nash_TDI's Avatar
Nice, the rears always scared me with the integrated ebrake. I've popped a few fronts apart.
Some S4 brakes I did for my passat:
I have my Front and Rear Brembos to rebuild next. 20 pistons of fun.
Old July 30th, 2015, 09:20   #20
3L3M3NT
3L3M3NT's Avatar
Espos Powder coating would have done it, but it was an extra $50/caliper. So I figured I would ask a friend if he could help with the rear calipers.
Looks like you've got quite the project in front of you.
Firefox fix
RTDI Build Thread
Old August 4th, 2015, 16:23   #21
3L3M3NT
3L3M3NT's Avatar
With the help of a friend, the rear bumper was removed from the car in preparation for the new R-Line rear bumper without the exhaust cutout.
Factory bumper.
End result.
To the this
Should look pretty good.
Firefox fix
RTDI Build Thread
Old August 4th, 2015, 16:43   #22
1854sailor
Resident Curmudgeon
1854sailor's Avatar
So, what are you doing with the exhaust? Turndown?
-George Bernard Shaw
Old August 4th, 2015, 16:54   #23
3L3M3NT
3L3M3NT's Avatar
Yep, a single turn down on the drivers side.
If you watch the dyno video you can see how much it smokes and they frown upon that at the track
https://www.youtube.com/watch?v=KxtVaL7ning
Hopefully with the new Race PD injectors and +120% Firad nozzles and the turn down exhaust, I won't have as much smoke
I'll find out in a month or so.
Firefox fix
RTDI Build Thread
Old August 5th, 2015, 06:33   #24
Nash_TDI
Nash_TDI's Avatar
Thanks to you I ordered the Rennline tow hook and gopro mount. Lucky my buddy is a dealer.
Old August 5th, 2015, 07:30   #25
3L3M3NT
3L3M3NT's Avatar
Glad I could help you see what a great product that Rennline offers.
I can't wait to use mine
Firefox fix
RTDI Build Thread
Old August 5th, 2015, 08:55   #26
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Smoke = wasted fuel. Hopefully you can get it dialed in. Good luck and keep us posted.
Old August 5th, 2015, 11:41   #27
3L3M3NT
3L3M3NT's Avatar
I guess I didn't think of it that way, but yes, that is a fair amount of wasted fuel going out the exhaust
Once I get it on the ground and plates for it, along with the +120% Firad injectors in the car it should hopefully be quite a bit less smokey
Firefox fix
RTDI Build Thread
Old August 7th, 2015, 12:36   #28
3L3M3NT
3L3M3NT's Avatar
Something else showed up to shave some more weight off the car
Teaser pic
Firefox fix
RTDI Build Thread
Old August 8th, 2015, 21:23   #29
3L3M3NT
3L3M3NT's Avatar
With the help of a friend, the rear brake kit from Racing Brake got installed last night and so did the amazing Racing Brake wheel stud conversion kit.
The links to both items, encase you're interested
Rear Brake Kit that works for any MKIV car and I believe a MKI Audi TT
http://www.racingbrake.com/Two-piece...-Re-p/2172.htm
Wheel Stud Conversion Kit. The reason I went with these over others is that they put a super nice 8mm bolt head on the end of the wheel stud, so you can snug them up :thumbup:
They're 80 mm in length, so they are perfect if you wanna add spacers to your setup, either to clear the calipers or to get that perfect stance.
http://www.racingbrake.com/RB-Wheel-...xl-p/vw-80.htm
Here are the pictures from RB Site on the wheel studs.
The super nice 8mm hex head :thumbup:
You can get either Cone seat or Ball seat lug bolts. Sadly in my case I need both cone and ball seat lug nuts, since the OZ Racing Ultraleggeras are Ball Seat
Pics of the brake install.
Here's how great a job Espos Powdercoating did to match the caliper to the special order Blue without having the front caliper in hand. I think the only reason the rear looks different is the rear is cast, compared to the front caliper that's machined.
Firefox fix
RTDI Build Thread
Old August 8th, 2015, 21:24   #30
3L3M3NT
3L3M3NT's Avatar
On the car with the wheel in place and I might be a little biased, but I think it looks Awesome!
This is how close the fronts would have been.
Actually the drivers side front has the wheel weights rubbing on the calipers, that's how snug it is with those Brembo 6 piston calipers and 355mm rotors.
That's it for today and hopefully the fronts can go on tomorrow.:beer:
Firefox fix
RTDI Build Thread
Full on RTDI build up. mtbr297 TDI Conversions 74 June 9th, 2015 06:43
Broke a part inside injector fuel pump. Can't find where to buy new part. Any ideas? 03TDIJettaWagon VW MKIV-A4 TDIs (VE and PD) 7 October 26th, 2014 12:06
Beware of supposed PD150 Intake manifolds with part number Part 038 129 713 BC tothemax TDI Power Enhancements 29 March 24th, 2013 21:51
2006 UK TDI Road Trip Part I: Wales Part 2 PlaneCrazy Road Trips 4 August 29th, 2006 19:19
2006 UK TDI Road Trip-Part I: Wales part 1 PlaneCrazy Road Trips 0 August 15th, 2006 19:39
Page generated in 0.17960 seconds with 11 queries
[Output: 147.78 Kb. compressed to 125.60 Kb. by saving 22.18 Kb. (15.01%)]
