Old September 20th, 2014, 17:23   #1
Trev21
TDI(s): 2001 1.9L
Default alternator issues
Is an alternater from a 2001 turbo gas compatible with a 2001 turbo deisel?
Trev21 is offline   Reply With Quote
Old September 20th, 2014, 17:45   #2
Ol'Rattler
Ol'Rattler's Avatar
Ah, no. The TDI alternator has an overrunning clutch pulley.
The problem with your alternator may well be the over running pulley which is replaceable for a lot less than the garbage alternators that AutoZone sells. The other problem that is common is a worn out brush/regulator assembly, also replaceable.
What are your symptoms? if you need to troubleshoot the overrunning clutch pulley, we can advise you.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old September 20th, 2014, 17:50   #3
Trev21
TDI(s): 2001 1.9L
The casing on my alternator broke and i need to repllace it. I have a guy who has one but his is a turbo gas
Old September 20th, 2014, 17:57   #4
Ol'Rattler
Ol'Rattler's Avatar
It might work if you can swap the pulleys, although the power output for a a TDI is usually higher than the power output for a gasser.
Being that the gassers don't have an overrunning pulley, the gasser alternator with the gasser pulley will destroy your tensioner.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old September 20th, 2014, 18:14   #5
Trev21
TDI(s): 2001 1.9L
Thanks so much for the help.
Old September 20th, 2014, 18:15   #6
Trev21
TDI(s): 2001 1.9L
2001 should be 120 amp?
Old September 25th, 2014, 10:19   #7
Powder Hound
Powder Hound's Avatar
Yes. If your car was equipped with a/c, then it should have a 120 amp alternator.
Old September 25th, 2014, 14:59   #8
Jettascuba
You can have the casing repaired/welded. (Can't you swap casings? Just a thought, I don't know)
Silver VW Jetta A4 TDI 2002 AHF, 421 000km, MAF and EGR delete
(VCDS Hex + CAN, ALH/AHF tools, BRM/BXE tools)
White VW Jetta A5 TDI BXE, 505 000km
Jettascuba is offline   Reply With Quote
Old September 25th, 2014, 15:33   #9
AndyBees
AndyBees's Avatar
I've been running a 90amp for over two years (three summers)! I got it in a trade. At the time, it was the quickest fix. Put it on and everything has worked fine. I plan to install the 120amp at the next TB change out ......... try at your own risk!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Alternator issues blueavlo VW B5 Passat TDIs 9 July 12th, 2013 15:07
Alternator Issues EMSi VW MKIV-A4 TDIs (VE and PD) 3 April 10th, 2011 08:21
Alternator Issues jsmith4425 Upgrades (non TDI Engine related) 6 January 19th, 2009 14:35
alternator issues moe03 TDI 101 4 December 6th, 2006 16:15
alternator light issues tditom Other VW Group TD(I)s 6 February 18th, 2006 17:42
Page generated in 0.13455 seconds with 11 queries
[Output: 89.17 Kb. compressed to 75.90 Kb. by saving 13.26 Kb. (14.88%)]
