Old September 23rd, 2013, 05:00   #1
Boyka
Boyka's Avatar
Default Camshaft caddy sdi pd or oem camshaft arl?
Hi, can clarify a question?, I need to know which is better as a replacement, if a oem camshaft or camshaft vw caddy a PD, the car is a tdi arl,crossing of each camshaft? ? Was difference from one note to another only with repro?
P.D.Sorry for my English.
A greeting and thanks.
Boyka is offline   Reply With Quote
Old September 23rd, 2013, 07:56   #2
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
I'm curious about this also
Lucian189 is offline   Reply With Quote
Old September 23rd, 2013, 11:45   #3
Boyka
Boyka's Avatar
Let's see if anyone knows anything about it.
Old September 23rd, 2013, 12:09   #4
JFettig
JFettig's Avatar
Have you tried searching?
http://forums.tdiclub.com/showthread...hlight=sdi+cam
JFettig is offline   Reply With Quote
Old September 23rd, 2013, 13:14   #5
Lucian189
TDI(s): 3.0 TDI CR
! saw that that there was a fail installing anl SDI cam,I have a friend and he has the sdi cam in a VP non pd ,and worked great from the first time..
Perhaps is the same case with PD..
Old September 24th, 2013, 05:58   #6
Boyka
Boyka's Avatar
Originally Posted by JFettig View Post
I think that thread is a rotatiba pump rather than a pump injecctor.I need to know the degree of the two camshafts and if the improvement over the OEM arl PD.
Old September 25th, 2013, 05:08   #7
Boyka
Boyka's Avatar
Nobody can helpme?
Old October 17th, 2013, 00:16   #8
Lucian189
TDI(s): 3.0 TDI CR
I have installed the sdi camshaft in my Pd.
Nothing bad for now,I can say it works perfectly fine.
From the part code is the same camshaft as the 2.0 PD 8v with DPF
Old October 17th, 2013, 07:47   #9
Boyka
Boyka's Avatar
Thank you very much for your answer,year and model of vehicle, please,To inquire in the house price.Voucher for 1.9 TDI PD??
thanks again, greetings.
Old October 18th, 2013, 08:34   #10
ryanp
ryanp's Avatar
I think they are worse than TDi cam, the BMM (2.0 version of BRM) has the same cam and they are worse than the 'normal' TDi cam
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old October 18th, 2013, 12:17   #11
Boyka
Boyka's Avatar
Thanks for your reply,listen out there that improves performance,but it is worse than not worth sdi.
There are some oem camshaft that improves performance in PD ARL?? of direct exchange??????
Old October 19th, 2013, 06:51   #12
Boyka
Boyka's Avatar
It's a camshaft oem prepared??
Old February 19th, 2017, 12:02   #13
krisv
TDI(s): ASZ
Any update if the SDI cam fits and brings any additional HP & Torque??
krisv is offline   Reply With Quote
Old February 19th, 2017, 12:19   #14
Lucas1976
TDI(s): 101
BMM owners update with cams TDI 101R oem or NPS 10mm lift
Old supply dbilas had much premature wear. Go to NPS one of the best building with DLC lifters
Lucas1976 is offline   Reply With Quote
Old February 19th, 2017, 12:37   #15
krisv
TDI(s): ASZ
So I have a 1,9 TDI ARL engine , how many HP and Torque can I gainwith an installed 038109101AE 2,0 SDI PD cam from a VW Caddy??
Performance camshaft VS Original camshaft (How much lift?) CrAzYDr1veR TDI Power Enhancements 1 February 22nd, 2013 11:56
ALH Camshaft and Camshaft Journal wear limit specification rbt_stack VW MKIV-A4 TDIs (VE and PD) 3 June 24th, 2011 09:52
PD camshaft: OEM vs. non OEM n2carz VW MKV-A5 Golf/Jettas 16 July 3rd, 2009 15:00
Fs: Sdi Camshaft Satiro Private TDI Items for Sale/Wanted 1 November 7th, 2008 08:31
Mk4 TDI Camshaft OEM Smog Private TDI Items for Sale/Wanted 0 January 6th, 2005 08:27
Page generated in 0.18862 seconds with 11 queries
[Output: 122.55 Kb. compressed to 100.88 Kb. by saving 21.67 Kb. (17.69%)]
