Old September 20th, 2012, 20:20   #1
DieselDevotion
TDI(s): 98 Tdi Jetta
Default Flat Towing a 5 Speed?
Hi everyone,
I did a quick search and didn't find what I was looking for. I have a 98 TDI Jetta with a 5 speed. Previous Owner already installed a homemade tow bar and mount. Is there anything I should know about flat towing my jetta?
I don't have an owners manual to referance if its recamended or not, and I'm not fimilar with these small car trannys. Is there a lube pump and if so which shaft does it run off of? If it on the output I'm fine but if its on the input can I just stick the car in gear and prop something between the seat and clutch pedal and keep it depressed?
I appreciate everyones help in advance,
Thanks Tom
98 5 Speed TDI Jetta - Just a beater to save on Fuel
89 F350 Powered by a 5.9 Cummins and 47RH auto
DieselDevotion is offline   Reply With Quote
Old September 20th, 2012, 21:41   #2
Herm TDI
Herm TDI's Avatar
I don't have an answer consering the lube pump for towing but I have been thinking about this issue for some time. I know of one A-4 TDI that suffered transmission damage resulted (allegedly ) from being flat-towed.
My thinking on this was to remove both drive shafts.
Using two outter CV joints (just the CV joint) to secure the wheel bearings.
In this manner the transmission would not have any loads put to it.
I will tell you with assurance that you do not want to even roll a VW without the outter CV joints installed or the wheel bearing will be ruined.
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old September 21st, 2012, 08:28   #3
DieselDevotion
I'm pretty sure the tranny does not have any type of pump and is just splash lubricated but thought someone could tell me for sure if any drivetrain parts could be damaged.
Old September 21st, 2012, 08:45   #4
DieselDevotion
I'm taking the Jetta down to Arkansas next weekend to pick up a diesel jeep grand Cherokee and was hoping I can flat tow it back home. A friend of mine just bought a 2012 with a six speed and said his manual sttated he could flat tow his car but only for limited distances, he couldn't remember exactly but thought it was around 20 miles, and to limit speed to less than 30 miles per hour. Any body know why?
I wouldn't doubt if they say that just for liability reasons. The same guy told me his car is recamended not to tow anything and the same car in Europe has a 2,000 pound towing capacity. Again probably worried about US lawsuits if someone way overloads a car than cant get all that weight stopped and sues VW
Old September 21st, 2012, 08:53   #5
d-man
d-man's Avatar
TDI(s): 05 jetta PD
Fuel Economy: 50MPG
I could not say for certain, but there is a couple transmission gurus on the forum. You need to post post this question in a drive line section.
'05 MK4 Jetta PD,Wheat Beige, Kerma Tune, CCV 3.0, ScangaugeII, Ventectomy, Cat delete, muffler delete, 2.5" straight pipe with resonator, LuK DMF clutch kit, Monroe VR6 suspension, hidden hitch for bike carrier, evolution belly plate,Traxon E 75w-90 gear oil, Lucas break-in additive, Duron E 10w-40 summer, 0w-40 winter. Bosio 800 nozzles, Stage 2 colt cam.
d-man is offline   Reply With Quote
Old September 21st, 2012, 11:36   #6
Ol'Rattler
Ol'Rattler's Avatar
A 5 speed has no internal pump, just like any other manual transmission. Unless someone comes up with a factual reason not to flat tow with the engine off, I don't think it would damage anything.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old September 21st, 2012, 14:05   #7
Phantomofheat
Phantomofheat's Avatar
Fuel Economy: 47-50
Flat towing a manual there should not be any problems flat towing an automatic not good.
Phantomofheat is offline   Reply With Quote
Old September 21st, 2012, 18:58   #8
MayorDJQ
Just make sure it's in neutral and knock your socks off.
MayorDJQ is offline   Reply With Quote
Old September 23rd, 2012, 06:07   #9
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
No issues, I have been in these transmissions and the big diff gear is what provides most of the oiling and that will be always spinning when the car is moving. Even the 5th gear area will probably get oil flow.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old September 29th, 2012, 12:05   #10
Ol'Rattler
Ol'Rattler's Avatar
I think you are confused. The OP is referring to towing the car behind a motor home or truck.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old September 29th, 2012, 12:09   #11
vwdiesel101
Fuel Economy: best tank:1250km 65 UK MPG
my bad sorry about that!
vwdiesel101 is offline   Reply With Quote
Old September 29th, 2012, 12:10   #12
Ol'Rattler
Ol'Rattler's Avatar
Almost missed that. No need to keep the clutch petal depressed. Just make absolutely sure the tranny is in neutral.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old September 29th, 2012, 12:30   #13
Ski in NC
Fuel Economy: 48-52 typical
Tough call on this one. Differential ring gear, pinion gear and output shaft will all be rotating. The fwd gears will be still, output shaft and syncros spinning. Oil splash around those gears is normally from the gears themselves, so things like the bearings between gears and output shaft could dry out.
Guess flat towing one of these is doing a bit of an experiment. Others in the rv community will probably know how they hold up.
A good thing to do is each time you stop, crank the tdi engine and rev it a bit to splash the oil around.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old September 30th, 2012, 18:11   #14
MayorDJQ
Why is this such a complex issue? The gears are simply submerged in oil. The fill plug is as least halfway up the side of the gearbox. As long ia it's full of oil, there should be no issue. There's no pump that supplies oil to the bearing or syncros when driving normally.
Someone must have a '98 owner's manual. Does it say not to flat tow a manual transmission? Does Bentley say not to flat-tow a manual?
Old October 1st, 2012, 07:54   #15
benzdoctor
I have a 98 Jetta TDI 5 speed, 225,000 miles. Have flat towed for 8 years behind Motor Home with no problems. Make sure it is in neutral and steering is unlocked.
benzdoctor is offline   Reply With Quote
Flat Towing NB w/ auto trans UberXY TDI 101 2 July 19th, 2012 14:13
Flat towing a Passat germ VW Passat Family (NMS and B7) TDIs (2012+) 4 April 1st, 2012 18:46
Flat towing a 10' Jetta tdi 6 speed MT Jim Karns General VW Discussion 1 February 10th, 2011 12:57
Flat towing another car with B4, can it be done? 914rrr VW MKIII-A3/B4 TDIs 9 October 1st, 2008 01:42
Flat towing? mavapa VW MKIV-A4 TDIs (VE and PD) 8 November 9th, 2006 11:55
Page generated in 0.17246 seconds with 11 queries
[Output: 126.71 Kb. compressed to 105.32 Kb. by saving 21.39 Kb. (16.88%)]
