Old March 2nd, 2012, 15:54   #1
dislexicmofo
Default Cam pulley wear/Cam bolt re-usable?
Two camshaft sprocket related questions. First, Is the bolt re-usable? I dont see another in my timing belt kit.
Second, I see some wear on the inside of the sprocket, since I am still diagnosing the belt failure I thought I would ask about it. It doesn't look like anything that would even throw off balancing but I like to play it safe, flood the forum with questions, and over analyze things
dislexicmofo is offline   Reply With Quote
Old March 2nd, 2012, 18:16   #2
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
It's fine.
33ft lbs is the specs but others set to 40 ish.
Make sure you are using lock tools.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old March 2nd, 2012, 18:25   #3
Ski in NC
Fuel Economy: 48-52 typical
Taper joint might have slipped when valves hit during belt failure. Clean up taper inside pulley and make sure it is a good fit on the cam nose. No burrs, raised metal, no rocking when fitted, etc. And yes, that 33ftlb seems way low in my mind.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old March 2nd, 2012, 18:25   #4
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
bolt is meant to be re-used
-tom
autos: 19 Subaru Forester, 14 BMW 535d xDrive
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old March 2nd, 2012, 18:44   #5
AndyBees
AndyBees's Avatar
I'd say it is a good possibility that the incident was the other way around. The Cam Sprocket slipped in the Morse Taper, thus allowing Valves to Kiss Pistons and break the TB. But, based on the view in the photos, there doesn't appear to be enough "scuffing" to indicate more than two or three degrees rotation.......the scuffing could be from the last TB job as it was being installed.
If you had TB failure, regardless of what caused it, there is a very little doubt that one or more Exhaust valves did hit piston(s).
Yes, as suggested, the spec is 33 ft lbs, but low 40s is best and works! Also, as stated by others, the bolt is re-usable!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old March 3rd, 2012, 12:41   #6
dislexicmofo
Thanks for the help! While were all here, I'm having trouble figuring out one thing here, when I set the cam timing, should the sprocket be on and torqued? Keep in mind I dont have a belt on yet.
Old March 3rd, 2012, 13:34   #7
tditom
You don't set the cam timing. You lock it at #1 Top Dead Center. When the flywheel (crank) is at its TDC mark and the IP is pinned at its reference point you slip the cam sprocket onto the tapered stub. follow the directions.
Old March 3rd, 2012, 21:48   #8
Mavrick
Fuel Economy: 48mpg. 55mpg on a good tank
Your pulley looks good and you can reuse the bolt. Blue lock-tite wont hurt.
Mavrick is offline   Reply With Quote
Old March 5th, 2012, 12:39   #9
Powder Hound
Powder Hound's Avatar
Don't put locktite on the taper. Just make sure the inside of the pulley and the taper on the end of the cam are both very clean and dry. When it is done properly and torqued down, they mate together such that the next time the cam sprocket is removed, a puller is required and there will be an audible snap when the pulley is pulled free (loosened) of the cam.
If you want to use some blue, do it on the bolt threads that hold the cam. But whether you use locktite or not, make sure the bolt threads are clean and dry and use a good torque wrench to insure it is tightened correctly.
Cam Wear? bradamoniom VW MKIV-A4 TDIs (VE and PD) 21 March 13th, 2012 12:45
Hows my cam looking Guru's or.. anyone who can tell cam wear... Carl2k7 TDI 101 16 September 5th, 2010 16:28
2000 vw Beetle cam pulley bolt Joseph Paniagua TDI 101 72 May 19th, 2009 13:09
TB change/ cam pulley bolt question 2TDIguy VW MKIV-A4 TDIs (VE and PD) 1 June 4th, 2005 06:41
TB change/ cam pulley bolt question 2TDIguy TDI 101 0 June 4th, 2005 06:21
Page generated in 0.15568 seconds with 11 queries
[Output: 91.59 Kb. compressed to 78.34 Kb. by saving 13.25 Kb. (14.47%)]
