Old September 29th, 2011, 08:30   #1
lglamb
Default warranty question
I recieved an IP as a warranty replacement for a reman IP that was purchased a few weeks ago. The reman IP came nicely packaged in fitted foam and a new box with VW stickers.
The warranty replacement pump came bubble wrapped, no stickers, in a generic box soaked with diesel fuel that had leaked out of the pump. This warranty replacement is apparently a take-off from a car, not a fresh reman that I had expected. It had diesel in it, and the pulley nut has been removed.
So my question is, is this acceptable? Or should I expect another proper reman pump as warranty for the original reman pump that lasted only a few days and a couple hundred miles?
lglamb is offline   Reply With Quote
Old September 29th, 2011, 09:02   #2
autdi
You bought a boxed, reman pump, under warranty it failed. I'm guessing they decided to replace rather than repair to honor the warranty. So, you should have gotten another one, just like the first one you bought. You didn't buy a take-off, don't accept one as a replacement. They get the failed one back after the swap, but the one to go on must match what they sent in the first place, and it doesn't sound like that's the case.
2000 NB TDI / 2003 NB TDI / 2006 Touareg TDI / 2015 Jetta TDI / 2015 Jetta TDI
autdi is offline   Reply With Quote
Old September 29th, 2011, 09:20   #3
lglamb
Followup, the vendor is going to send out another (proper) reman pump.
Apparently he had a few pumps from a different supply stream. Hasn't been a problem with the others, apparently just mine.
Anyway, he's standing behind his service and sending another pump. This box of return cores is going to get kinda heavy.
Lowell
Warranty question Shenandoah VW MKIV-A4 TDIs (VE and PD) 2 February 3rd, 2008 23:35
warranty question XMariner Upgrades (non TDI Engine related) 1 April 2nd, 2005 10:01
warranty question DrinkDiesel VW MKIV-A4 TDIs (VE and PD) 2 June 16th, 2004 16:48
Warranty question JeremyMartin TDI 101 5 April 6th, 2004 14:55
Warranty/$ Question AZDennis Private TDI Items for Sale/Wanted 9 May 2nd, 2002 12:20
Page generated in 0.16072 seconds with 11 queries
[Output: 56.67 Kb. compressed to 51.47 Kb. by saving 5.20 Kb. (9.17%)]
