Old August 23rd, 2010, 13:59   #1
ishmael010
Default Nicktane fuel filter installation
All-
I've looked around a bit, as I seem to have seen it before, but can't run across an install of a Nicktane Fuel Uber-Filter. I'm sure it's pretty straight-forward, but I was hoping to see another members install pictures to get a leg up.
Thanks!
Ish
'12 Audi A3 Premium Plus TDI DSG, Malone 1.5 Tune
ishmael010 is offline   Reply With Quote
Old August 23rd, 2010, 14:27   #2
Honeydew
Ish, forgive me if you've seen it but the pics on his page for the filter kit show some good install pics. It does look straight-forward, just unbolt the old bracket, bolt on the new one, attach filter to head, install filter onto bracket, position nipples, connect hoses, prime.
http://nicktane.com/osc/product_info...products_id=47
Honeydew is offline   Reply With Quote
Old August 23rd, 2010, 18:58   #3
streeker02
it is stoopid easy. No harder than replacing the OEM filter.
streeker02 is offline   Reply With Quote
Old August 23rd, 2010, 19:38   #4
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
The two worm clamps are kinda difficult to get at with the HUGE filter in place... That's about the hardest part of the install.
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Old August 24th, 2010, 08:53   #5
ishmael010
Default Nicktane...
installed it last evening. One question I have for those who already have theirs installed successfully, what torque is required on the bolts through the Banjo fittings, I tightened them down pretty snug, but seem to have a little leak, and it's not coming from the hose clamps.
Thanks!
Ish
Old August 25th, 2010, 14:51   #6
ishmael010
Default bump!
Any information on the torque requirements?
Ish
Thanks!
Ish
Old August 25th, 2010, 19:14   #7
darkhorse
darkhorse's Avatar
Fuel Economy: mid 40's
Thanks!
Ish
Mine didn't leak & I didn't use a torque wrench. If it's leaking a wee bit I'd say just snug it down another 1/4 turn or so.
'06 Golf GLS 5 speed, Evo skid plate, Koni FSD's with Shine RSS, SBC stage 3, SMF, KERMA custom tune, R 32 snorkel,PD 150 airbox,MAF,TIP & manifold, K3B,R 783's, Colt stage 2, EJ SMIC, piping by ID Parts, Whitbread 2.5" DP, Aero muffler, 3"KERMA SS pipes, Sigma 5 short shifter, .681 5th gear & Peloquin, Nicktane 1 um fuel filter & DG/Amsoil bypass filter.
darkhorse is offline   Reply With Quote
Page generated in 0.16899 seconds with 10 queries
[Output: 76.63 Kb. compressed to 66.12 Kb. by saving 10.51 Kb. (13.72%)]
