Old October 21st, 2013, 16:05   #76
ncroadwarrior
ncroadwarrior's Avatar
TDI(s): 04 JSW bew
Amsoil makes a reusable paper filter...their nano tech filter media for desert storm vehicles...
take out and shake, vacuum off ..good to go
bd
04 jetta wagon, BEW, 09A
RC2, F06 Stg 2 cam,17 turbo, E-codes, Koni's, TT LCA's,
Skid Plate, tint, cat/vent/muffler/intake B'fly'd..frostheater..cat 2micron FF.
ncroadwarrior is offline   Reply With Quote
Old October 21st, 2013, 16:11   #77
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
bd
That's not paper then. It's synthetic media
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old October 28th, 2013, 14:44   #78
silverbox
silverbox's Avatar
Fuel Economy: 55mpg highway@100kph
I just checked, and I'm a bit surprised.
I've had the Amsoil EAA208 nanofiber in my airbox for about 6 years. It is still filtering well.
I may change it to an OE winter filter tomorrow.
http://www.amsoil.com/shop/by-produc...code=EAA208-EA
KERMA tune, PDliftpump,11mmIP Race 520's. PD150 Intake manifold&TIP, 1722 turbo, Upgraded IC pipes and Eurojet SMIC.Stealth racepipe. 2.5DP+catback areoturbo2525 muffler. Peloquin LSD.
Koni FSD's +VR6 springs, 23mmRSB, 16x7w/Conti DWS. GLI Recaros, Wingnut short shifter, Ecodes w/relays+60/100h4's.
Cat2 Fuel filter DG/Amsoil Bypass filter
silverbox is offline   Reply With Quote
Old October 28th, 2013, 20:43   #79
Special K 608
TDI(s): 2010 A3
http://www.goapr.com/products/filter_vwr.html
Anyone try this?
Special K 608 is offline   Reply With Quote
Old October 28th, 2013, 20:54   #80
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Originally Posted by Special K 608 View Post
Quote from the advertising blather:
The VWR Intake Filter upgrades replace the restrictive factory paper filters with an improved, high flow and reusable lifetime foam filter.
The filter that came from the factory will outflow your engine. Check your manual for the replacement schedule, you will find that it seldom requires service.
Good thing you asked us, isn't it!!
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old October 28th, 2013, 21:52   #81
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
6 years and how many km? What kind of cleaning intervals?
Old October 29th, 2013, 12:58   #82
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
...this is what I'm running now.
Maybe no hp increase but this might be the best pick for longevity.
It might flow better than a Mann/Fram/etc. but more flow usually means less filtration, so who knows
02 Jetta, 17:1 CR 81mm ASV, Colt cam, Peloquin LSD, Raxles, FueLab pump, 12mm/DE143, Gibonta 5 x 0.018, NX nitrous, 6+6 turbo, Bilstein coilovers
MKVII GTI 6MT, full build, 525hp
MKVII GLI DQ381, 93 tune only, daily driver
loudspl is offline   Reply With Quote
Old October 29th, 2013, 16:31   #83
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Just different filtration. Nanofiber synthetic media vs. paper media. AEM has a nanofiber panel filter, too. AFE, too.
Old October 29th, 2013, 18:42   #84
brew1
Fuel Economy: TDI 38-42 mpg, drive it like you stole it.
Why not just clean and re-install per Amsoil instructions?
03 Jetta TDI Wgn, 17/22, RC5, Bosch T4 .216, PP 2.5 DP & IM, Euro SMIC, 11mm IP, AFE CAI, 3" MAF, 3 Bar MAP. Sold
15 GSW SEL DSG TDI Kerma Stage 2
15 Audi A3 Quattro DSG Stock
16 Audi A3 S-Line Quattro DSG JB4, APR DP & Intake
brew1 is offline   Reply With Quote
Old October 30th, 2013, 20:14   #85
silverbox
silverbox's Avatar
About 140,000km
Old October 30th, 2013, 20:19   #86
silverbox
silverbox's Avatar
I bought a new filter, installed it and saved the amsoil one I may give it a good vac and use it again.
Amsoil says its good for 4 years, so I thought I would change it.
It was not letting anything into the intake, inside top of the airbox was spotless.
Old October 30th, 2013, 22:00   #87
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
About 140,000km
Cleaned how often?
Old October 31st, 2013, 15:56   #88
silverbox
silverbox's Avatar
2 or 3 times
Old November 18th, 2013, 10:47   #89
ramljak
Fuel Economy: on mTDI best 3.2 l/100 km(73,5 mpg),worst >14 l / 100 km(<16.8 mpg)
take that one from golf 5 sdi od a6 3.0 tdi
ramljak is offline   Reply With Quote
Old November 26th, 2013, 10:44   #90
Rawtek
Rawtek's Avatar
Default Proof that a CAI can work
Hi folks,
I thought I would chime in here since I have some CAI retaled news that I'm sure will spark some discussion.
We just came off a dyno session while testing our new Passat exhaust & tune where we found a pretty significant power improvement with our cold air intake on both the Passat and Jetta. We did 3 pulls with the stock airbox installed, 3 pulls with no airbox installed (just MAF and tube extension) and finally 3 pulls with our CAI. After all the hype about intakes being worthless on our 2.0lcr TDIs we were pleasantly surprised by the results...13whp over the stock intake and about 8whp over just the intake tube extension. These were with a AEM DryFlow filter and yes, the original VW filter was fresh and clean.
Feel free to discuss and/or call me a liar while I dig up the dyno sheets.
Rawtek
TDI Performance Exhaust Systems
www.rawtekinc.com
Rawtek is offline   Reply With Quote
Page generated in 0.17631 seconds with 10 queries
[Output: 136.64 Kb. compressed to 114.52 Kb. by saving 22.12 Kb. (16.19%)]
