Old September 21st, 2009, 19:53   #1
CharlieT
Default Cam wear on BHW
I was hoping to avoid this... but looks like I have a lot more wear on my BHW cam than I originally thought.
Here is the #3 cam lobe, not sure if it is exhaust or intake ? It is the inside lobe on #3 (assuming #1 is front of car, closest to timing belt).
and another view of same...
Hard to see in the pics, but the best I could get.
It has a very sharp edge, chamfer is totally gone, and I can feel a significant flat spot near the tip of the lobe.
Lifter is very hard to see, but I do see some clear wear marks (gauling) in the centers of both #3 lifters that the other lifters do not seem to have.
Pics of lifters were impossible... but will take some once I pull the camshaft.
Looks like I am in for :
1x Camshaft 038109101AF $618.12
8x Lifters 038109309C $22.08 each
8x 038103714A - Rocker Shaft bolt - $4.08 ea
10x 038103714 - Camshaft Bearing Cap bolt - $4.08 ea
So, about $900 all in...
What else should I do while in there ?? TB is new, BS is done.
And anyone have a leads on the two tools I need to remove the camshaft sprocket ?
T10051 and T10052 ?? Found them online for about $80 each.
I cannot see how to get by without the T10051 Counter-hold tool ? Camshaft Sprocket retaining bolt is tightened to 100Nm.
History on this car is 100k miles, with full VW service by previous owner... but very likely with the wrong oil..
http://forums.tdiclub.com/showthread.php?t=249795
I have been trying to track down an intermittent hard start, and a rough idle... I think this cam wear may be the cause ?
http://forums.tdiclub.com/showthread.php?t=257992
But the good news is I got her for only $8500, on the basis that I may have to spend a few bucks..
http://forums.tdiclub.com/showthread.php?t=249500
So, $2.5k for BS and now $1k for the cam... I am still only $12000 in and have a car that should run and run....
2012 NMS TDI SEL, 39k
CharlieT is offline   Reply With Quote
Old September 21st, 2009, 20:55   #2
Franko6
The sharp edge on the cam lobe is a dead give-a-way.
If you are interested, I'm doing a cam re-engineer for the PD's. Look in the MK5 section.
I put part of the post up(no part pictures are posted yet). Basically, you drill an oil path to the top bearing shell, cut a radial groove in the top bearing shell to provide proper oiling to the camshaft and replace the tty bolts with a set of non-stretch 12.9 high chrome rolled thread rocker shaft and cam cap bolts, torqued to 45 and 22 ft lbs respectively. I hate paying $100 for bolts you throw away every time you look at the cam.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Franko6tdi@gmail.com
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old September 21st, 2009, 21:10   #3
CharlieT
Frank,
Very interested, thanks !! I will go look.
(Thanks also for giving me some guidance / ideas on the phone for the 1Z head rebuild I had a few months ago... rebuilt it myself, huge sense of accomplishment, works great now !)
Especially interested in the new bolts.. TTY seems a huge waste..
Charlie
Old September 22nd, 2009, 00:05   #4
hid3
Banned
You need a full set of cam bearings too.
hid3 is offline   Reply With Quote
Old September 22nd, 2009, 06:35   #5
TDIsyncro
TDIsyncro's Avatar
TDI(s): Audi/TDI x 2
Fuel Economy: 50-60mpg HWY, depending on speed and wind
I followed this procedure this past weekend. It went well. I used a dremel and diamond bit for the groove in the bearing shells. Had one hairy moment when the drill bit tip broke inside a hole..but got it out after an hour of trying. lol I will check on things in a couple months just to see how it's all working.
I like the bolt change out idea. I would of done that too had I thought of it in advance. Next time. What a waste of money in bolts!
As for bearings, I just replaced bottom shells. Top shells were in new condition.
2001 Audi A4 - New Project - 2.0TDI CR 450HP All Turbo
http://forums.tdiclub.com/showthread.php?t=270527
2007 Canyon w/2011 TDI CJAA CR
http://forums.tdiclub.com/showthread.php?t=415533
TDIsyncro is offline   Reply With Quote
Page generated in 0.17948 seconds with 10 queries
[Output: 67.04 Kb. compressed to 59.16 Kb. by saving 7.88 Kb. (11.76%)]
