Old January 11th, 2009, 16:12   #1
pedrodiesel
Fuel Economy: 50 m.p.g.
Default unplug electrical connector
I found an un plug electrical connector. Between the engine and the cabin compartment, close by the EGR valve. I went under the car, above the turbo, below the turbo, to see where could be connected. I did not find a plug to connected it.
I look all over engine compartment.
(My car have the check engine light on)
The OBC II scanner shows code P2100
TAC ( Throttle Actuactor valvE)
Could it just be for an electrical device that my car just does not have (example: sun roof, heated seats...) ?
Pedrodiesel
2004 Golf Gl TDI
pedrodiesel is offline   Reply With Quote
Old January 11th, 2009, 16:14   #2
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
That connector probably plugs into the device by the EGR valve. That device is the intake changeover / throttle valve.
-Jason
Present:
2018 Tesla Model 3 DM. 50,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 32,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old January 14th, 2009, 17:17   #3
pedrodiesel
Default Found plug connector
Hello compu85, I found the connector, right under the EGR valve.
Thnaks
Pedro
"engine light" still on.
Old January 14th, 2009, 17:20   #4
whitedog
You will need to get that code cleared.
Old January 14th, 2009, 17:24   #5
pedrodiesel
Discuount autoparts have a Scanner, can the code be erase with that scanner?
Thnaks
Old January 15th, 2009, 17:22   #6
pedrodiesel
Default check engine light came back ON
I erased the codes after plug in back the eletrical connector I found unplug by the EGR valve.
Code was gone for 3 hours, and came back.
Will see if it goes off by itself.
Pedrodiesel
Golf 04
Old January 19th, 2009, 15:28   #7
Spock-Mckoy
TDI(s): 2002 Golf GL
Fuel Economy: 35 city/50 hi
Hi, I bought a scanner at Harbor Freight. It came with 2 cables, cd. I used it on my dodge ram no problems with check engine light codes. I erased codes. Now, I plug it into my golf connector under dash, scanner powers up so I know it is getting power from the car, but it can't communicate with the car. I bought it mainly because of the check engine light on in the golf. Does the golf have a special needs scanner? or OBDll work ok? 2003 golf tdi. The scanner connector is the same shape in my 02' dodge and 03 golf. The golf won't start and the glow plug light no longer lights on my dash. [this was another reason to buy scanner] temp was minus 8 the other morning when I tried to start it.
Spock-Mckoy is offline   Reply With Quote
Page generated in 0.16320 seconds with 10 queries
[Output: 75.33 Kb. compressed to 65.16 Kb. by saving 10.17 Kb. (13.50%)]
