Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old April 29th, 2002, 23:27   #1
AZDennis
Fuel Economy: 42
Default Warranty/$ Question
I found a used 2000 Golf TDI GLS 5 spd, 52,000 miles, lux, monsoon, and 16" rims (needs new tires). It seems a little rough, and already ate one MAF. I finally have a matching 2002 at the stealer waiting for me.
1. The stealer tells me that as the second owner, my warranty would already be expired on the 2000. Is this true?
2. The used car doesn't seem to pull until it hits 2200 rpm. Then it wants to wind out to 3500 rpm. I would be concerned driving in that range in a TDI. Is this normal after so many miles, or could it be from the way the car was 'broken' in?
3. Both options seem priced high. $19,300 new, $14,900 used. Any thoughts? (Seller, if you're reading this, I would be happy to hear from you too. [img]images/icons/wink.gif[/img] ) Decisions, decisions...
AZDennis is offline   Reply With Quote
Old April 30th, 2002, 08:45   #2
gearhead
gearhead's Avatar
TDI(s): 2001 Golf
Fuel Economy: 52/48/42
Default Re: Warranty/$ Question
Without knowing the service record and past history of the vehicle (what type of oil & change intervals, intake cleaned?...). Hopefully it has received regular servicing with a good CH-4 Diesel synthetic oil (Amsoil, Delvac 1...) The used car will need a timing belt replacement in 8,000 miles (tack on $400-$600 for this procedure), may need brakes also. I would try to swing for a new TDI or used with documented service & repair records.
gearhead is offline   Reply With Quote
Old April 30th, 2002, 18:33   #3
AZDennis
Fuel Economy: 42
Bump...
Old April 30th, 2002, 18:46   #4
hotrodtdi
get the new one the way you want it and the warranty for peace of mind. [img]images/icons/wink.gif[/img]
hotrodtdi is offline   Reply With Quote
Old May 1st, 2002, 06:48   #5
oldpoopie
oldpoopie's Avatar
agreed. Warrantee is nice.
Old May 1st, 2002, 07:42   #6
TDI-NEVER-DIE
TDI(s): bora
Fuel Economy: 70
if you can afford it, new is always new. you can break it in the way you want and you will always know the full history of the vehicle. good luck. [img]images/icons/cool.gif[/img]
TDI-NEVER-DIE is offline   Reply With Quote
Old May 1st, 2002, 09:31   #7
CloudNine
Hey all,
While we're on the subject, can anyone explain why the Golf TDIs are priced below Jettas to begin with, but seem to hold their value better?
Thanks,
Tom
CloudNine is offline   Reply With Quote
Old May 1st, 2002, 10:32   #8
AZDennis
Fuel Economy: 42
Thanks for all the suggestions. I'll try to get the $ for the new one.
One reason I think they hold their value is because they seem to be rare in comparison to the Jetta. The opposite probably holds true in Europe.
Old May 1st, 2002, 21:20   #9
applehead
hey dennis are you interested in a get together in the phoenix area in the future? there's a couple of fellows up there with a posting on the "G/T/G" forum. maybe we can give them a little "southern comfort" from the old pueblo!
applehead is offline   Reply With Quote
Old May 2nd, 2002, 12:20   #10
AZDennis
Fuel Economy: 42
Applehead - I am interested, but until I actually have one I'm the wrong one to get involved. I am still torqued at VW and their Tucson stealership because of their delays and apparent deception on my car order. I see other TDIs around, and I will try to get in touch for the GTG idea. Thanks for the HU.
Page generated in 0.16625 seconds with 10 queries
[Output: 88.23 Kb. compressed to 74.49 Kb. by saving 13.74 Kb. (15.57%)]
