Tankthecarman
My 2001 Jetta ALH has an issue that’s confusing me. I had an alternator go out last week. Wasn’t charging at all. I ordered a replacement (remanufactured not the $600+ from VW), than pulled the old one out. Found the clutch sprigs had failed. I operated under that assumption and completed the swap. The new alternator is charging at 13.5-14.3 but when you are driving the battery light will flash twice and then go off...wash, rinse and repeat. No codes in memory and I’m waiting for my PC to update so I can use my VAGCOM to see what might be available to look at with it. Anybody have any thoughts and/or suggestions?
