Old November 13th, 2013, 13:58   #31
Fingers302
I just purchased a used 2013 SEL with DSG. Dealer quoted $680 for full service. I'm brand new to diesel cars and this forum. First post. Looking forward to all the information and money saving tips/advice from the site.
Fingers302 is offline   Reply With Quote
Old November 13th, 2013, 14:18   #32
Rico567
Are you talking about the 40K w/ DSG service? If so, that is well within the 'ballpark' of dealer prices discussed in this and other threads. The only way to realize significant savings is to do it yourself, or try to perhaps find an indie who knows what they're doing. And I italicized the last part of that sentence for good reason. If they're not experienced diesel mechanics, and this type of car specifically, it's risky.
[URL=http://www.fuelly.com/driver/rico567/passat]
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old November 14th, 2013, 06:05   #33
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
Just knocked out all the 40k stuff on mine. I went with the dealer (Winner, Dover DE) for the DSG service to the tune of $349 out the door. The rest I did myself for $112 ($40 for 4.5 quarts Pennzoil Ultra Euro-L, $40 fuel filter, $20 cabin filter, $12 oil filter).
Be careful putting in the new cabin filter in cold weather. It's tight quarters under the dash and the frame of the filter will snap if bent any more than slightly. I proved it.
My advice for the fuel filter is to completely surround the filter housing with shop towels. There will inevitably be a few drops of diesel spilled when you break the lid loose. No need to disconnect any fuel hoses like on the older model TDIs. Slowly pull the old filter out having a rag or plastic bag ready to put it in. Visually inspect inside of canister. I basted out all fuel at 20k and wiped inside dry. In retrospect, that was overkill. For 40k, I saw that it looked great so I left it filled with fuel and just slowly sunk the new filter in. Torque the lid back on and then run this test in VCDS to bleed any air remaining in the housing:
Fuel Pump Basic Settings
[Select]
[01 - Engine]
[Basic Settings - 04]
Choose the Transfer Fuel Pump (FP) test from the drop down menu followed by [Go!] to activate the Basic Setting. The EDC should display "Running" and the electric fuel pump will run. After the result of Finished Correctly appears click [Stop].
2011 BMW 335d - JR 2.8, 600 lb/ft
Blue_Hen_TDI is offline   Reply With Quote
Old November 16th, 2013, 08:37   #34
Sandhopper
Fuel Economy: 38
Hum, just had my 30K done and got the quote for the 40k... $850+ (~450 for the normal service and ~400 for the DSG) for the 40k service and the DSG service. Might have to drive home to slower DE to get that DSG service Blue_Hen got.
2013 Passat SEL TDI - Tungsten Silver Metalic with Titan Black Interior
Sandhopper is offline   Reply With Quote
Old November 16th, 2013, 12:03   #35
Ace Deprave
I received a coupon for 10% off of the 40k service, so mine ended up being $611 with tax. Still expensive, but pretty reasonable compared to what most are posting on here.
Ace Deprave is offline   Reply With Quote
Old November 16th, 2013, 17:06   #36
r11
So it would have been over $700, with taxes etc. Ouch ! The parts are $120-ish, oil included - I guess they charge for 6-7 hours of labor ?
r11 is offline   Reply With Quote
Old November 16th, 2013, 18:01   #37
Rico567
Yes- and the lion's share of that labor goes into the ridiculous lashup that is the VW DSG oil change procedure. It's nonsense, designed by armchair engineers without the slightest consideration for maintenance costs.
- Adam Savage
Old November 17th, 2013, 17:41   #38
r11
Ain't aces car an se - wo the dsg ?
Sent from my Nexus 10 using Tapatalk
Old November 18th, 2013, 07:36   #39
Ace Deprave
It's an SE, but with DSG (SE with sunroof and nav).
Old November 18th, 2013, 19:33   #40
StoneCrab
StoneCrab's Avatar
Just had my 40k service done today. Total with tax was $575. I had a 15% coupon from the dealer so it brought it down to $495. Still seems likes a lot, but better than other places. Work order says 1.3 hours for the oil, fuel filter, pollen filter change. 1.5 hours for the DSG fluid and filter.
5 units (quarts?) of DSG gear oil at $24.27/unit = $121.35. Is it made from unicorn blood?
StoneCrab is offline   Reply With Quote
Old November 18th, 2013, 20:41   #41
Blue_Hen_TDI
Corinthian unicorn blood.
Old November 20th, 2013, 08:28   #42
MadCat
I'm having the 30k maintenance done on my 2013 Passat (SEL, DSG) this morning. The service rep gave me heads-up on the 40k maint
$710
(Day Vw/ Audi Pittsburgh)
Unicorn blood indeed
Sent from my SCH-I545 using Tapatalk
MadCat is offline   Reply With Quote
Old November 22nd, 2013, 09:04   #43
APT
I just had my 30k service and asked for estimate for 40k. $750 for 40k + $400 for DSG = $1150. I'll find an alternate in the next 8 months.
2012 Passat TDI SEL Night Blue/Cornsilk
2017 Subaru Outback 3.6R Limited Lapis Blue
2011 Suburban 2500 family towing beast
APT is offline   Reply With Quote
Old November 24th, 2013, 16:43   #44
redbarron55
Unborn Corithian unicorn blood O-negative. Raised in certified german reserves with no barbed wire, organic only.
redbarron55 is offline   Reply With Quote
Old November 27th, 2013, 13:46   #45
ChadS99SVT
I just got a quote from one dealer I frequent. $857.00 for the 40k+Dsg service.
He mentioned how to get a 15% discount but ugh hoping I can still find it cheaper than that at another dealer.
I have another month or so.
ChadS99SVT is offline   Reply With Quote
Has anyone use Wheaton Service center in MD for a 40K Service with DSG change? j1mbo Eastern USA 6 September 11th, 2014 05:36
First DSG service, 40k service done! Jav9882 VW Passat Family (NMS and B7) TDIs (2012+) 8 April 27th, 2013 06:03
40k service checklist pkhoury VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 July 23rd, 2012 12:12
20,000 mile service - checklist torifile TDI 101 18 October 19th, 2006 00:20
40K Service Checklist BoraTdi VW MKIV-A4 TDIs (VE and PD) 7 December 9th, 2000 01:47
Page generated in 0.17442 seconds with 13 queries
[Output: 128.48 Kb. compressed to 107.26 Kb. by saving 21.22 Kb. (16.52%)]
