N nev89117 New member Joined Apr 4, 2005 TDI Jetta, 2003, silver Jul 26, 2005 #1 cooling fans won\'t shut off and A/C dosn\'t work The cooling fans on my 03 Jetta TDI will not turn off, running the battery down. The A/C also will not work now. Has anyone experienced this problem?
C cage Top Post Dawg Joined Mar 25, 1999 Location lakewood, ohio Jul 26, 2005 #2 Re: cooling fans won\'t shut off and A/C dosn\'t work Probably the freon temp/pressure switch or the coolant temp switch. It thinks the AC or engine is over heated.
