I HOOKED UP WITH SOMEONE WITH A VAG-COM BECAUSE MY CEL WOULD COME ON AFTER ABOUT 20-30 SECONDS. IT SHOWED SEVERAL FAULTS SOME OF WHICH I THINK ARE QUESTIONABLE.THE FIRST FAULT WAS 18057-POWERTRAIN DATA BUS: MISSING MESSAGE FROM ABS CONTROLLER
NEXT 16764 GLOW PLUG/ HEATER CIRCUIT (Q6) MALFUNCTION (INTERMITTENT)
THEN 01316-ABS CONTROL MODULE 49-10 NO COMMUNICATION- INTERMITTENT
THEN SAME FAULT AGAIN AT ADDRESS 19
AND LAST WAS 00943 AND 00944 HEATED EXTERIOR MIRROR DRIVER AND PASSENGER SIDES
I RESET THE FAULTS AND THEY HAVENT COME BACK BUT ITS ABOUT 60 IN CHICAGO SO THE GLOW PLUGS PROBABLY ARE NOT BEING ACTIVATED. ANY IDEAS FOR THESE FAULTS? ALSO ABS SEEMS TO WORK GREAT. THANKS DON
