Water on passenger side floor
JohnnyCanal
Frederick, Maryland
2011 Jetta TDI Wagon
Bought a used 2002 Jetta wagon, every time it rains we end up with a pool of water on the passener side and inside door sill. We plan to replace the door seals, but the water also seems to be coming in near the center console on the floor. My husband thinks it started after we changed the cabin filter. I think we just noticed it after that. He also thinks it's getting worse, I think it just never has a chance to dry out so it seems worse. My previous car (a Toyota) had a condenser tube that would occasionally get disconnected and cause a similar problem, but I can't seem to find anything similar on the Jetta. The problem has gotten so bad that my husband finally put the dehummidifier out in the car to dry it out, which seems to be working, but would make it hard to drive far since the extension cord is only 100 feet. Any ideas?
--Cattayl (JohnnyCanal's wife)
Joe_Meehan
Ohio USA
NB TDI, 2002.5, Silver
I doubt if it is the door and if so it is not likely the seals, it would be more likely the drains in the bottom of the door.
The three most likely sources are:
1. Blocked A/C condensation drain
2. Blocked sunroof drain (if so equipped)
2. Blocked fresh air intake. This is the drain for the water that goes in the grill right in front of the windscreen and is usually clogged with leaves and gunk. Often it shows up in the fall.
2004STARWARSTDI
LAKELAND, FL
2004 Platinum Gray GLS Jetta / 2006 Silver Jetta with DSG
AC drain
The AC drain is hard to find.:eek: It is behind a flap on the firewall inside engine compartment. Tried reaching mine but space is cramped.:mad: Looks like only way is from bottom of car to reach it. I would suggest running AC and see if you have any water dripping on pavement.:cool:
pruzink
Granbury, Texas
GLS, 2004, silver
I have had this same problem with my daughter's car
My daughter has a 2001 Jetta that had this same problem with the passenger side front floor getting wet. I did several things to try to eliminate this problem and I am guessing that it was probably the cabin filter that caused it. Every year, I change the cabin filters on the cars. You need to be very gentle and careful when removing the plastic cover to get at the filter as it has to be cocked just a little bit and angled just right to remove it without breaking it. The filter needs to be removed with the plastic tray that it sits in if you expect to get it in right and it only fits correctly 1 way. I even removed the housing for the cabin filter to be sure that it was sealed propperly (I don't think this was a problem, and removing it required removing the plastic trim piece just below the windshield which meant the windshield wiper arms had to be removed, kind of a PITA). A small piece of the plastic cover that you remove to access the cabin filter was broken off, I cut a piece of thin aluminum (Home Depot sells thin strips of aluminum in various widths) and used some black paint and black RTV compound to patch the piece that had broken off.
I also checked the AC drain. You do need to access this from underneath the car. There is a flapper perferation in the foil insulation on the firewall under which there is a rubber fitting where the AC coil drains. I used a can of compressed air for cleaning off computers (I had the red plastic tube attached and fit a small piece of very small ID tygon hose just big enough to squeeze over the red plastic tube), the drain opening is up higher than you can probably reach with your arm so I attached the tube to a paint stick and snaked it up inside the AC drain fitting. I don't think the AC drain was plugged, I just wanted to be sure that I ruled it out as a possibility. The can of air did do a nice job of blowing that line back.
If you have a sunroof, I would also verify that all 4 drains from it are clear. There is one in the front and rear of the sunroof on each side. The front drains go to a small black rubber nipple on the front door posts. I use a flower pot watering pitcher to pour some water into these drains and verify that it runs out freely at the nipple. If it does not, kneed the nipple between your fingers as it has a very tiny hole and gets plugged easily (I used a pair of nips to cut a corner off of the end of mine to enlarge the hole).
I have also seen posts in here about people that have had this problem after the door was opened for maintenance. There is a plastic membrane that must be put back propperly or the side doors can leak water in. To get the water dried out I removed the floor mat and put down towells with heavy bags on them to absorb the water. The floor carpet has a pretty heavy rubber backing so it can take a while to suck the water up through it.
Joe_Meehan
Ohio USA
Yea that seems really odd, and it looks difficult to get to.
LeeM
Hagerstown,MD
2015 Passat SE, 2002 Jetta Reflex Silver
I had water coming through the cabin air filter after hard rains. It turned out to be caused by an accumulation of leaves and dirt between the front wheel well liner and fender. The drains at the bottom of the rear end of the liner were blocked, the run off from the windshield backed up and cabin air intake was the next lowest drain. Turn the steering wheel as far as you can with it unlocked, remove a couple of screws and it can be easily cleaned.
