MontanaShaun
I have searched and am still struggling with a non working wiper issue on a 2006 jetta I just picked up.
All fuses are good, washer spray pump works, found the wires to hood switch a bit damaged and repaired them (hood open indicator shows when open, off when closed) have power to red/white wire to motor, power to purple signal wire and ground continuity to negative terminal battery. Got another motor/linkage from salvage yard today and still no wipers. What am I missing? I dont have a vagcom nor do i know anyone with one. Is there programming needed for wiper module? I can tell the motor was replaced before and the harness at motor has been repaired. Anyway to bench test one of these motors safely?
Thanks in advance for anyone time and valued info.
