Matt-98AHU
Sorry I didn't see this sooner!HOLY S***! The above title states the number of days +/- 7 days of fighting the P0401 battle. Blood, sweat, tears, currency, and mental health all thrown at this problem. Thank you, Matt! So the question then becomes with these following results, where do I head?
Basic Settings 67: Absolute utter failure, OFF 540 ON 525
Basic Settings 68: OPEN-23 CLOSED-90
Basic Settings 78: Block 1: 90 Block 3: Remained at 3 the entire time
So do I pull the Low Pressure EGR Valve off the cooler and run Basic Settings 67 to ensure the valve is moving? Is it possible it is just the valve and not the DPF/EGR filter issue? I do not have any other codes beside the P0401. I did have to replace the Low Pressure EGR Filter because the canister blew out and was sitting on the bottom pipe connected to the EGR cooler. After replacing the filter, it was about 2,000 miles before the P0401 came back.
First thing, do double check and be sure you don't see any soot in the exhaust. If there is any soot, the DPF is cracked and is contributing to the problem.
But, judging by the numbers you gave here, it does almost look like the low pressure EGR valve is not opening as much as it should, hence the very small difference in MAF reading as well as minimal pressure drop across the filter (there would be a minimal pressure differential if the valve is barely opening, right??).
So yes, I would say you're on the right track. The low pressure EGR valve itself bolts into the cooler on the back of the engine. I'd say it's worth trying to replace it. Or at least take it out and see if you can find any evidence of blockage in the system.
