azbiodiesel
Hey guys,
My 2002 jetta has been sitting behind the plant where i work for the last month as I have not had time to figure out why it hasn't been starting. Riding the bus isn't that bad but its getting old. I have not been using biodiesel in the car for the last year.
So, I looked through the FAQ for cold weather/no starting. I have electrical working, lights, the works. Engine cranks over quickly, but doesn't fire. It makes that weird spooling/whirring when it doesn't catch. I looked through some threads and one guy described the noise pretty well and it was determined to be the starter. But I didn't see anything in the no start faq about the starter. Does this sound plausible? How much does one cost and how do you install it? FYI the glow plugs/harness was supposedly fixed a few months back after the car wouldn't start when i came back from a trip. There is no fault light showing on the dash.
Now compounding the problem is the fact that my injector pump is leaking from using 100% biodiesel and then switching back to regular petrol. The seals swelled and then shrank I think. However despite this, I think i confirmed that fuel was getting to the engine. I took off the main injector line (the one you have to bleed out when you change the fuel filter). And there was plenty of fuel shooting out of it. However I can't confirm its the right psi, or quantity of fuel. Anyone know how much a new IP/rebuild costs? Im guessing its pretty pricey. Is this something I could do myself? I have found a Viton Seals kit from dieselgeeks that looks pretty cool. I have access to tools at work but I have very limited experience at car maitenance.
Any help is greatly appreciated, thanks.
