2003 Jetta TDI with 320,000 miles has started fine for five years in western NY. This week it has been 35-40 degree lows and it is now not wanting to start at all. Replace glowplugs due to vehicle mileage as well as a new glowplug bridge, due to deterioration of older bridge. Still no start. Increased glowplug duration time per post:
How To extend glow time with Vag-com - ALH http://forums.tdiclub.com/showthread.php?t=123304
Car still will not start. Engine seems to turnover more quickly than normal. My next step is to check compression of motor. Cyclinder head fully rebuilt 40 K miles ago along with timing belt replacement and at that time, initial engine mechanical timing was correct, i will recheck if necessary . I have installed three full timing belt kits on this car to date with no problems. Car is a manual transmission and has been getting about 42 miles per/gal. Injectors are original and are probably in need of rebuilt and replace; but have been working adequately enough prior to this no start episode.
Appreciate any advice or forum links.
Thanks again
Thanks again
